RV.Net Open Roads Forum: Travel Trailers: Black water tank health concerns and questions
 > Black water tank health concerns and questions
Boon Docker
Posted: 08/28/22 10:19am Link  |  Quote  |  Print  |  Notify Moderator
profdant139 wrote:
I think that we should take the OP's concerns seriously and not poke fun at him. There is no reason to be rude.
Some clowns think it's funny to be rude. [emoticon]
dieseltruckdriver
Black Hills of SD
Posted: 08/28/22 10:44am Link  |  Quote  |  Print  |  Notify Moderator
I wanted to add one more thing that hasn't been posted. Everything in your black tank is something you ate or drank. There's nothing else in there, unless you add a small amount of chemicals. The grey tank is water and soap. The same that you just washed your hands with.
The best part of owning an rv over tenting is having your own private facilities with you. Once you start using it, you will wonder why you waited so long.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
Lantley
Ellicott City, Maryland
Posted: 08/28/22 11:01am Link  |  Quote  |  Print  |  Notify Moderator
Just because it went in your mouth does not mean its germ or bacteria free when it comes out the other end! I'm not sure what your point is!
The grey tank also contains grease , skin folicles and stagnant water.
Waste water water is not germ free. Otherwise we would not need traps to seal off sewer piping.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Posted: 08/28/22 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
That’s the best part of a RV if you’re not paranoid.
valhalla360
No paticular place.
Posted: 08/28/22 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
The point is...if your fecal matter has a nasty disease present, as the only users of that facility, you have already been exposed to it. This does assume you don't let a lot of random people into your RV to use the facilities.
Traps are not to prevent germs from getting into your living space...they won't (household or RV). They are to stop sewage odors and methane from entering the living space. There are roof vents to allow them to escape.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Turtle n Peeps
California
Posted: 08/29/22 10:37am Link  |  Quote  |  Print  |  Notify Moderator
I think you should use public facilities for several reasons.
#1. You show concern about your health by having tanks under your trailer. This being the case, I think you will really have a problem with health concerns when it comes time to dump your waste.
#2. If you have concerns and if your health is so tenuous that you have a problem walking to a bathroom I think you will really have a problem dumping your tanks.
In any event, I wish you the best of luck at whatever decision you make.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
Cocky_Camper
Rock Hill, SC
Posted: 09/06/22 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
I am more concerned about sitting on the toilet that someone else sat on in public...
2004 Sea Breeze by National RV - 8341
Former Coaches:
2006 Keystone Zeppeline 291 - TT
2000 Aerolite Cub F21 - Hybrid TT
1991 Coleman Pop Up
Formerly known as: hybrid_camper
pbeverly
South Carolina
Posted: 09/07/22 05:01am Link  |  Quote  |  Print  |  Notify Moderator
Tis true, especially since guys in public restrooms have very bad aiming skills. Also have to worry about dropping your drawers on the ground while you sit due to the same bad aiming skills.
Ridgeway, SC
Bumpyroad
Virginia
Posted: 09/12/22 06:14am Link  |  Quote  |  Print  |  Notify Moderator
I have a friend who changes the toilet seat whenever he gets a new house.
bumpy
NamMedevac 70
Reno
Posted: 09/12/22 10:10am Link  |  Quote  |  Print  |  Notify Moderator
One must be cautious when dealing with such issues. Gloves and mask were helpful when dumping and handling the hose. Never used their hose to fill the freshwater tank in the campgrounds where available. Never used fresh water tank water for drinking, etc.
Will not be viewing further
