chiefward
Covington, GA
What would cause the water pump to work on shore power but not on battery? Battery charged to 12:8 volts. Fuse good. Any suggestions are appreciated.
2011 Fun Finder by Cruiser RV, model X210WBS
2017 Ram, 1500, Tradesman,
10,000 Equal-I-zer hitch
way2roll
Wilmington NC
Battery disconnect?
2023 FR Sunseeker 2400B MBS
2oldman
NM
Time for the voltmeter.
stickdog
Somewhere, USA
Do other 12v items work on battery power when not hooked to 120v external power?
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
BB_TX
McKinney, Texas
Do any of your 12 vdc devices work?
Is your battery disconnect switch turned to the disconnect position?
bgum
South Louisiana
Bad ground?
opnspaces
San Diego Ca
Are you saying the fuse is good because it visually looks good? Or did you put a volt meter on the fuse while it's plugged in?
If just a visual check you will need a meter to check to verify that there is 12 volts going in and out of the fuse.
At the fuse panel find good 12v positive and ground so you know your tests will be valid. Then leave the ground connected and move the positive lead to the water pump fuse and probe the back of the fuse while it is plugged into the panel and see if you have 12 volts. Probe both holes on the fuse and the meter should read the same. If you measure 12.63 volts on one hole you should also read 12.63 volts on the second hole.
If the readings are different replace the fuse. if both readings are zero you have no power going to the fuse.
If all fuses read zero find the reverse polarity fuses and check them.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
chiefward
Covington, GA
Just checked and nothing works on battery. Not receiving 12volt power at fuse panel.. Replaced 30 amp inline fuse, no change. I have power at junction box under bed. Inspected wires from under bed to fuse panel, and no breaks on damage seen. Tomorrow I’m going to see if I can find some 8 gauge stranded copper wire to jump from under bed junction to fuse panel. I checked all connections at fuse panel and buss bar.
chiefward
Covington, GA
I am so redfaced I’m glowing. BB_TX you were right the switch was off..I just bought this trailer and still learning all it’s ins and outs,,I’m definitely going to put a guard over this button. I thank all for your comments and suggestions. Won’t make this mistake again.
BB_TX
McKinney, Texas
It happens. If that’s the biggest mistake you make you will be doing great. Most of us have done worse at least once in our RV life.
