TenOC
On the road -- Full time
On my 5th wheel where the 50-amp electrical cable plugs in, the black screw “ring” connector that holds the cable in place has broken off. Is it possible to replace the ring only and not have to replace the whole connection? I am thinking about just ignoring the problem because it appears that the only function of the ring is to make sure that the cable is not disconnected. Your thoughts on the issue?
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
bgum
South Louisiana
Etrailer and Amazon has them for sale about $8-9.
enblethen
Moses Lake, WA
Verify the brand of your connector. They are not all the same.
Park power/ Marinco
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
bgum
South Louisiana
It appears he just wants the ring and not the the cover.
He does need to make sure of 30 or 50 amp.
bgum
South Louisiana
https://www.park-power.com/en/p/500ELRV/50A-EASY-LOCK-RING
edited 08/29/22 10:17am by bgum *
TenOC
bgum wrote: It appears he just wants the ring and not the the cover.
50 Amp. I do not know how to replace the ring only. I will need the replace the complete cover.
Is the ring REALY necessary? How many do not use (tighten) the ring?
dougrainer
Carrolton, Texas
TenOC wrote: bgum wrote: It appears he just wants the ring and not the the cover.
ON 50 amp, the pins will lock into place. The ring is just a way to help keep out moisture. Doug
PS, not really needed. That is why you insert and twist
enblethen
Moses Lake, WA
The standard straight in twist lock cord body puts strain the the electrical components. The locking ring reduces this stress. A 90 degree adapter reduces the stress and reduces possibility of failure.
adapter
bgum
South Louisiana
The ring will slip over your plug. You will need to work it some.
Lantley
Ellicott City, Maryland
dougrainer wrote: TenOC wrote: bgum wrote: It appears he just wants the ring and not the the cover.
Doug I know you are our resident guru. but I strongly disagree that the ring is not needed. The ring keeps the plug sucure in the socket it keeps the plug tight. When the plug gets loose you get arching , scorching, heat, all symptoms of a bad connection.
The ring keeps the plug tight and secure.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
