RV.Net Open Roads Forum: Onan marquis 7000 shutting off after like 15 min/overheat
 > Onan marquis 7000 shutting off after like 15 min/overheat
Chrisbouch
Stow mass
Posted: 08/29/22 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
I know it's overheating, but this is air cooled a d don't see any blockage in the grate. Is this likely a thermostat?
MountainAir05
New Mexico
Posted: 08/29/22 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
low oil, sucking air in the gas line.
Put a new gas line on and drop in a fresh gallon of gas.
RLS7201
Posted: 08/29/22 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
Which Onan Marquis 7K gas do you have? QG or NHM.
Richard
95 Bounder 32H F53
460/528 stroker
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
Southern California :(
Posted: 08/29/22 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
Like, could be a number of things. Low oil is probably the culprit. Last oil change by hours is?
Chrisbouch
Stow mass
Posted: 08/29/22 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
It's the same gas that's in my Gulfstream, so seems to be doing okay. Not sure the generator model. Does this help model number 7hgjab-9000
theoldwizard1
SE MI
Posted: 08/29/22 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
Exhaust leak.
FloridaRosebud
Melbourne
Posted: 08/29/22 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
How do you know it's overheating? What is the engine code? My 5500 would stop after 15-30 minutes, and it was the fuel pump. How many hours do you have on the Genny?
Al
IB853347201
Eastern Ontario
Posted: 08/30/22 06:19am Link  |  Quote  |  Print  |  Notify Moderator
Al
Mine did the same thing, fuel pump as well. New fuel pump, problem solved.
2010 Suncruiser
Chrisbouch
Stow mass
Posted: 08/30/22 07:46am Link  |  Quote  |  Print  |  Notify Moderator
Not getting a code. Maybe it's not overheating you're right. I guess it could be a fuel pump or the exhaust leak. Exhaust leak sounds right honestly as it's hotter than heck and the hot air seems to be blowing as much out of unit as it does out the exhaust and works when cold weather
way2roll
Wilmington NC
Posted: 08/30/22 08:08am Link  |  Quote  |  Print  |  Notify Moderator
If you are sitting still on a hot day and they are running hard it's not uncommon for these gensets to shut down with an overheat code. The genset panel inside would show a code if that happens.
2023 FR Sunseeker 2400B MBS
