RV.Net Open Roads Forum: Tech Issues: Portable Solar Generators
 > Portable Solar Generators
JtTribe
California
Posted: 08/30/22 08:36am Link  |  Print  |  Notify Moderator
Anyone have any exsperience with solar Generators? I'm currently putting the EBL 1000watt voyager and 100watt apollo solar panel through its paces. So far so good! I spend most of my time overlanding in my Jeep. I have been able to do alot more boondocking! I will report back soon!
Have a blessed day! Stay Outdoors!
Posted: 08/30/22 08:44am Link  |  Print  |  Notify Moderator
There’s a fun discussion about these from just a few days ago….
pianotuna
Regina, SK, Canada
Posted: 08/30/22 08:45am Link  |  Print  |  Notify Moderator
A better solution may have been a large battery and an inverter, adding solar panels.
Generally these "solar generators" are quite pricey. They are convenient if not much power is needed.
* This post was edited 08/30/22 09:51am by pianotuna *
Regards, Don
Posted: 08/30/22 10:25am Link  |  Print  |  Notify Moderator
Did you forget that you actually started the last thread 10 days ago about the same thing?[emoticon]
bikendan
Goodyear, Arizona
Posted: 08/30/22 10:43am Link  |  Print  |  Notify Moderator
Why did you start the same thread all over again? Your previous thread is two threads below this one.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
Southern California :(
Posted: 08/30/22 11:43am Link  |  Print  |  Notify Moderator
A 100 watt solar panel will get you 5.5-5.7 amps under perfect conditions which can be had 4 to 5 hours a day maximum. Not many paces until your "generator" is dead.
time2roll
Posted: 08/30/22 12:34pm Link  |  Print  |  Notify Moderator
I think the idea is to only comment if you actually have one to avoid all the other banter and unrelated advice.
675w Solar pictures back up
shelbyfv
TN
Posted: 08/30/22 01:41pm Link  |  Print  |  Notify Moderator
Given that multiple postings of the same are prohibited, perhaps they will consolidate or at least lock one of them.
Y-Guy
Tri-Cities, WA
Posted: 08/30/22 11:11pm Link  |  Print  |  Notify Moderator
Thread Closed, please refer to the Portable Solar Generators that you started August 20.
