2112
I had to replace my landing gear switch and plate and still need to replace the battery vent and reseal all of it.
How do I remove the old sealant without scratching the fiberglass siding? Will acetone clean this off?
2013 KZ Durango 2857
LouLawrence
Traveling the US!
You should be able to cut the caulk with a razor knife at the joints and peel the vent off. You can then use a plastic putty knife (scraper, something) to get the majority of the remaining caulk off and reinstall with the same type off caulk as you will likely not be able to remove it all.
Fisherman
Angus, Ontario, Canada
Go to home Depot and get some caulk remover, there's a variety of brands even safe for use on fibreglass.
2112
I'll see what I can find. Thanks
I agree with a razor scraper to remove most of the caulk and then perhaps a product like GOO GONE (do not know if it will work) or gentle rubbing as caulk is not all that sticky (low grade adhesion).
Good luck.
JimK-NY
NY
I have never had caulk remover, but mineral spirits work well.
2112
I finally found time to get back to this.
The GOO GONE cleaned it very well but didn't remove it.
Mineral spirits and a little elbow grease took it right off.
I was so impressed how well the GOO GONE cleaned it I went around and cleaned up caulk with it. It looks new again.
Learjet
Louisiana
WD40 works too.
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
dodge guy
Bartlett IL
A razor blade. Score the sealant athen remove the trim. Then gently take a new blade and cut the sealant flush with the surface, with the blade almost flat with the surface. Then clean it up with some adhesive remover. They make plastic razors if you are worried about damaging the surface.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
2112
My eyes aren't sharp enough to trust my hands with a razor blade. I didn't want to scratch the surface
