RV.Net Open Roads Forum: Travel Trailers: towing hitch for new trailer
 > towing hitch for new trailer
Jack1776
oregon
Posted: 09/01/22 06:11am Link  |  Quote  |  Print  |  Notify Moderator
Purchasng a used coachman 2021 spirit northern ultra lite 1943Rb. Its about 24 feet weighting about 4900lbs with a hitch weight of 520lbs. Will be towing w/ a 2020 ford F-150 w/ the small eco engine and a tow capacity of 7300lbs. I am 76 years old and looking for hitch that is capable but hopefully easy to hook up. Thank You
ken56
Tennessee
Posted: 09/01/22 07:15am Link  |  Quote  |  Print  |  Notify Moderator
Equal-i-zer brand is a good one. A 10,000 gross/1000 hitch weight rated one will do just fine for your weight of trailer. Like any hitch it is on the heavy side. I ordered one of the hitch gripper handles to use to carry mine and it does help. I think the Equal-i-zer is easy to hook up compared to some others with the chains type.
TenOC
On the road -- Full time
Posted: 09/01/22 07:47am Link  |  Quote  |  Print  |  Notify Moderator
Get a Hensley Arrow or a Pro-Pride. Each cost a few $$. I purchased mine used on eBay. IMO it should be against the law to sell a TT without one of these hitches. ... [emoticon] .... [emoticon].
NO MORE TAIL SWAY. I once had a wheel come off my TT while driving 75 MPH and did not know it until a car passed me and wave me down to pull over. The Arrow probably saved my life.
Search the posting to see other comments. I am 85 and not problem hooking up. A few tricks to learn. Most important is do NOT turn you steering wheel the last 5 feet when you back up to the hitch.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
afidel
Cleveland
Posted: 09/01/22 07:53am Link  |  Quote  |  Print  |  Notify Moderator
If you're worried about weight the lightest I'm aware of is Andersen.
https://andersenhitches.com/product/weight-distribution-hitch/
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
Second Chance
Wherever...
Posted: 09/01/22 09:03am Link  |  Quote  |  Print  |  Notify Moderator
Those weights are all empty weights - pretty useless numbers and should not be used for determining an appropriate tow vehicle or hitch. The GVWR of that trailer (fully loaded) is 6,500 lbs. which will yield a tongue weight around 780 lbs.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
Gdetrailer
PA
Posted: 09/01/22 10:21am Link  |  Quote  |  Print  |  Notify Moderator
Rob
X2!
Actually 6,500 lbs GVWR has the potential of 975 lbs at 15% of tongue weight when fully loaded..
780 lbs is only 12% of TW, the max towing stability is achieved when your TW is at 15% of the trailer weight.
Yes, the recommended TW range is 10% - 15% and 12% is in sort of in the middle, it is better to shoot for 15% than 12%.
Maxing out your TW to 15% is advisable.
Granted, most likely you will not get to the GVWR but one should always plan for it just in case you end up getting close to the GVWR..
Boomerweps
Hills of PA
Posted: 09/01/22 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Don’t have one but it seems the lightest and easiest to adjust is the Anderson.
I have a Husky Centerline TS and it works great but is sometimes noisy and heavy for me. And I’m a young whipper-snapper at 67!
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
Southern California :(
Posted: 09/01/22 11:00am Link  |  Quote  |  Print  |  Notify Moderator
"weighing about 4900lbs with a hitch weight of 520lbs."
That's just a spec over 10% and too light IMO. Shoot for 13 to 14% of the loaded weight of the TT.
canoe on top
Denver, CO, US
Posted: 09/01/22 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
A reasonable going camping weight for this TT might be around 6,000 lbs. That would indicate a tongue weight of 600- 900 lbs. 700-800 would be reasonable. An Equal-i-zer 10,000 - 1,000 should serve very well. The hitch head is heavy.
JIMNLIN
Oklahoma
Posted: 09/01/22 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 10000 gvwr car hauler carrying a 7000 lb blue tractor/implements. Trailer axles scales 8840-9260 lbs depending on which implement is on the tractor.
I some times pull it with the wifes '16 1500 chevy 4wd 5.3 engine 6 speed tranny short bed.
I use a Husky Centerline TS with 1200 lb bars as the tractor has a cab and makes a top heavy load above the trailer deck. No more trailer over steer on sudden lane changes or curvy state/county roads.
I'm 80+ and have no problems installing/removing the hitch minus the bars. Its a friction style hitch and can groan a bit if the L brackets are rusty where the bars slide. After the first couple of turns no more noise.
