RV.Net Open Roads Forum: Truck Campers: DC to DC charger
 > DC to DC charger
Page of 7
SoonDockin
Oklahoma
Posted: 09/03/22 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
I have been using a 30 amp Victron also. Works well. If your vehicle has the charging capacity, you could run more than one 30 amp unit.
2022 Ram Laramie 5500 60" CA New pic soon
2018 Arctic Fox 1140 Dry Bath
Sold 2019 Ford F450 King Ranch (was a very nice truck)
deltabravo
Spokane, WA
Posted: 10/12/22 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
jdcellarmod wrote:
Can the charger be used in conjunction with an inverter (2000 watts) to run the refrigerator on electric while on the road?
Yes. I do it all the time when driving to save propane.
WarrenS65
SoCal
Posted: 10/25/22 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
I have the Victron Orion 30 A and it's working great. I plan to add a second one as well. My truck has dual alternators so I'm not worried about overworking them.
I run my absorption fridge when parked at home, on the move, or when I have shore power. At camp I run on propane to save the batteries for other stuff.
* This post was edited 10/25/22 06:39pm by WarrenS65 *
2022 F450
2023 Host Everest
2021 Yamaha YXZ1000R
1987 Honda TRX250R
2002 Honda 400EX
2023 Yamaha Raptor 700SE
2018 Look 24' enclosed trailer
pianotuna
Regina, SK, Canada
Posted: 10/25/22 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
I've installed the 20 amp dc to DC charger. I love the results. I started a thread on what I've been able to glean.
Regards, Don
deltabravo
Spokane, WA
Posted: 10/26/22 06:39am Link  |  Quote  |  Print  |  Notify Moderator
I have been using a 30 amp Victron also. It works very well.
* This post was edited 11/24/22 09:57am by deltabravo *
terrybk
Central Coast California
Posted: 10/26/22 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
I'm running a Renogy 40A but with dual alternators. If I unplug one alternator you can see the voltage sag for a second and then it comes back up as the PCM cranks up the alternator output. But I didn't want the alternator to run super hot with a lot of current draw (recharging both the starter and camper batteries at around 80 amps) so I installed the second alternator. The voltage doesn't blip.
2005 Chevrolet 3500 SRW 4X4 LB/CC D/A
2006 Bigfoot 25C9.4LB
CEK0515 and a dog
Reisender
NA
Posted: 10/26/22 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
I’m not sure what the source is here. Is it the trucks 12 volt system you want to use to charge the truck campers battery? Why would you need a DC to DC converter for that. That is what the trucks charge line is for on the 7 pin. What am I missing?
We use a DC to DC converter but it is from one static battery bank to another. So no alternator etc.
StirCrazy
Kamloops, BC, Canada
Posted: 10/26/22 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
the 7 pin wire is small, lots of voltage drop. so if your altanator is putting out 13.5V, just to pick a number, by the time it is down at your rv batteries it could be in the 12's, also unless you buy a battery isolater the rv can suck down the truck batteries if you leave it plugged in. I believe newer vehicles may come with that but the wires are still to small.
a dc to dc charger mounts as close to the battery as you can, and you run a new wire, or use your 7 pin, directly from the truck battery to the DC to DC. the charger then turns what ever it is getting into a proper voltage for your batteries. as a bonus it also isolates your truck batteries from the rv batteries so you cannot drain your truck down.
if you use the 7 pin charge line to feed it the inlett amps will be up to 50% higher than the ouput amps, the reason to run a larger wire on a plug is to lower that difference by making less voltage drop on the feed.
so you can also set the charging profiles on the dc to dc charger so if you have deep cycle batteries it will get the best charge as aposed to what ever the starting batteries in the truck get. same goes for gel and Li.
I am installing on in my camper in the spring, this will let me have a emergency source of power for charging if I hit a ton of dark days when I am lait fall/early winter camping. my solar handles everything but last year I saw three days of rain and dark and I was hitting the 50% mark on y deep cycle from running the furnace all the time. I have a 10 day cussion now with the LiFePO4 cell I built but, with the dc tyo dc, in 1.5 hours I can recover 24 hours power use if I need to.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
Bedlam
PNW
Posted: 10/26/22 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
I am collecting the pieces for a Renology 60A DC to DC setup. I run half worn out AGM's because they are free to me, so every once in while my solar cannot keep up and the batteries don't have sufficient capacity.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD
Reisender
NA
Posted: 10/26/22 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the explanation. That all makes sense. I didn’t think it would be a problem with the drop from the alternator but yah. I get it.
We use ours very rarely. When we are dry camping we have a little 2000 watt propane generator we use for keeping the battery up on our little trailer if the solar conditions are bad. (Meaning shady sites etc). But we have stayed at a no generator campground a couple times. We plugged into the 12 volt receptacle in the trunk of the Tesla which kicks out 13.6 volts and then set the DC to DC converter to 14.4 volts to trickle charge the trailer battery for half a day. Got us thru the last couple of days of a camping trip. Handy devices.
Thanks again for the explanation.
Page of 7
 > DC to DC charger
