RV.Net Open Roads Forum: General RVing Issues: charging an EV at a campground
 > charging an EV at a campground
Page of 10
shelbyfv
TN
Posted: 09/02/22 08:45pm Link  |  Print  |  Notify Moderator
Bummer about the WV park food. Here in TN the parks usually have good restaurants. I love a buffet!
pianotuna
Regina, SK, Canada
Posted: 09/02/22 09:07pm Link  |  Print  |  Notify Moderator
32 x 240 = 7680 watts
The pedestal is rated for 12000 watts.
Regards, Don
3 tons
NV.
Posted: 09/02/22 09:49pm Link  |  Print  |  Notify Moderator
Maybe they’ll eventually offer an incentive like ‘Infrequent Flyer Miles’ !! (Sorry, just the cynic in me - couldn’t resist a bit of cheap humor - lol)…
3 tons
time2roll
Posted: 09/02/22 11:25pm Link  |  Print  |  Notify Moderator
Yes they even knew better and still showed up with just 32 amps instead of 40 while wanting the maximum charge rate.
Rookies.
675w Solar pictures back up
Fulltimer50
Kerrville, Tx
Posted: 09/03/22 06:02am Link  |  Print  |  Notify Moderator
rhagfo wrote:
Using the 30 amp to 50 amp likely confused the charging unit as both legs of the power were on the same phase. Well 15 hours to full charge from 22%.
This is the answer!
George
2011 F350 PSD CC LB 4X4 DRW Lariate
2015 Mobile Suites 41RSSB4 5th Wheel
wanderingaimlessly
Buggs Island lake
Posted: 09/03/22 06:16am Link  |  Print  |  Notify Moderator
pianotuna wrote:
wanderingaimlessly wrote:
Would have been nice to know if they found the issue. I use a Hughes Power Watchdog, which scans the post, something like that here would have been helpful.
The issue is the four pin plug is for 240 volts. The 30 to 50 adapter does 120 on each leg so it will not work. One could make an adapter tht would work.
A way to test would to be to use the 20 vehicle plug, with a 30 to 20 adapter. That would present the correct voltage to the charging adapter.
I was thinking of the 30 amp plug issue.
Tvov
CT
Posted: 09/03/22 06:25am Link  |  Print  |  Notify Moderator
Wow... FIVE days to charge on a 120 outlet?? I knew they took awhile, but not that long. Then they switched to the 50amp, and the charging time dropped to 14 hours... yikes, still I did not know they took that long.
For some reason I thought a 120 outlet would be like an overnight charge, not 5 days.
2021 F150 2.7
wanderingaimlessly
Buggs Island lake
Posted: 09/03/22 06:26am Link  |  Print  |  Notify Moderator
The ideal of the EV being the cure all for environmental ills is about the same as Eugenics being a cure all for societal ills a hundred or so years ago.
And it is approached by its acolytes with the same zeal and desire to force it upon all others. Most are and were well intentioned but still,,,
Misguided then, misguided now.
Reisender
NA
Posted: 09/03/22 07:11am Link  |  Print  |  Notify Moderator
It is in some commuter cars but not on a truck. Big batteries in a truck.
We are rarely on a 50 amp site but for our SUV to charge on a 50 amp site is typically 7 or 8 hours. Almost always we are on a 30 amp site so much longer. Having said that we rarely arrive at a campground below 50 percent on the battery so it’s usually not that bad.
Cheers.
time2roll
Posted: 09/03/22 09:56am Link  |  Print  |  Notify Moderator
L1 is good for about 50 miles per day for overnight charging in a car. Maybe 30 miles in a truck as the economy is lower just like gasoline vehicles.
Trouble with L1 (120v) is the power is limited to about 1400 watts and the computer running, cooling pumps, etc. will use about 300 watts or 20% of the power. Charge at 7000 watts and the overhead is only 4%.
I originally ran my LEAF on L1 for the first six months (22 mile commute) because Nissan wanted a crazy $4200 to install a home L2 connector. Eventually got a Schneider for $800 and still using it 10 years later.
Page of 10
