pianotuna
Regina, SK, Canada
Hi all,
Some interesting results.
https://youtu.be/Xnyc6oNsB_w
Regards, Don
toedtoes
California
The 20a outlet looked like it was scorched and the 30a outlet did also. I wouldn't have hooked up my RV or vehicle to that pedestal without checking it out first.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
Y-Guy
Tri-Cities, WA
Moved from Tech Issues to General RVing Issues
BB_TX
McKinney, Texas
toedtoes wrote: The 20a outlet looked like it was scorched and the 30a outlet did also. I wouldn't have hooked up my RV or vehicle to that pedestal without checking it out first.
Actually it looked like most of the older campgrounds and RV parks I have been to.
rhagfo
Portland, OR
Using the 30 amp to 50 amp likely confused the charging unit as both legs of the power were on the same phase. Well 15 hours to full charge from 22%.
wanderingaimlessly
Kerr Reservoir
Would have been nice to know if they found the issue. I use a Hughes Power Watchdog, which scans the post, something like that here would have been helpful.
toedtoes
California
BB_TX wrote: toedtoes wrote: The 20a outlet looked like it was scorched and the 30a outlet did also. I wouldn't have hooked up my RV or vehicle to that pedestal without checking it out first.
I'd be testing them too.
pianotuna
Regina, SK, Canada
wanderingaimlessly wrote: Would have been nice to know if they found the issue. I use a Hughes Power Watchdog, which scans the post, something like that here would have been helpful.
The issue is the four pin plug is for 240 volts. The 30 to 50 adapter does 120 on each leg so it will not work. One could make an adapter tht would work.
A way to test would to be to use the 20 vehicle plug, with a 30 to 20 adapter. That would present the correct voltage to the charging adapter.
3 tons
NV.
Y-Guy wrote: Moved from Tech Issues to General RVing Issues
Geeeze, The $64k question is Why??…Is not this primarily an electrical related issue??
3 tons
NV.
Seems like this will make soft-starts and surge guards more important than ever, and likely lead to increased camp fees as well…(a bit of altruism comes to mind)
3 tons
