RV.Net Open Roads Forum: Travel Trailers: Best leveler for travel trailer?
 > Best leveler for travel trailer?
OregonMan
Oregon
Posted: 09/01/22 11:57pm Link  |  Quote  |  Print  |  Notify Moderator
Hi guys been looking online at leveling blocks for travel trailers and it seems like they're all made out of plastic and a lot of people complain about them shattering under the weight of the tires. My trailer weighs around 5,000 pounds and wondering if you guys have a leveler you could recommend? Seen some guys just use blocks of wood but isn't there a risk of slippage if you just use some blocks of wood? Thanks for any info.
afidel
Cleveland
Posted: 09/02/22 01:27am Link  |  Quote  |  Print  |  Notify Moderator
My trailer is 7k+ loaded and I've had no issues with the Camco blocks, we generally just use them for the stabilizers and use the Anderson levelers for the tires but I've had sites that were so unlevel that I had to make stairs 5 blocks high with the Camco and they worked fine.
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
toedtoes
California
Posted: 09/02/22 01:43am Link  |  Quote  |  Print  |  Notify Moderator
I've used the plastic leveling blocks with both my motorhome (approx 7,500lbs) and my trailer (about 3,400lbs). I have never had one break. If they do break, then odds are you didn't have them flat on the ground or didn't have them fully under the tires so they were stressed unevenly.
Many people use wood blocks. I've never heard folks complain about slippage. The main differences between wood and plastic blocks are wood blocks are heavier/bulkier but often free.
There is also the curved levelers. Many people like those.
Chocking your tires is also important regardless of your choice of levelers. You don't mention if you have a single or double axle. If you have a double axle, the X chock is popular.
I have since started using a BAL leveler for the trailer and really like it.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
eHoefler
ozark mountains
Posted: 09/02/22 03:35am Link  |  Quote  |  Print  |  Notify Moderator
I have used the Lynx blocks for 15 years under our Landmark 5th wheel, pushing 18,000 real hard. Never had one break or crack. When parking on gravel, I always stack them on a 6' long 2"x10". Stacking them on gravel will destroy them for sure.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
Tvov
CT
Posted: 09/02/22 05:47am Link  |  Quote  |  Print  |  Notify Moderator
OregonMan wrote:
.... Seen some guys just use blocks of wood but isn't there a risk of slippage if you just use some blocks of wood? Thanks for any info.
I think you mean "planks" of wood? I use 2x8 and 2x10 planks, roughly 3 feet long (long enough to have both tires fit on it with a 2 axle trailer). Ends of the planks are cut at a 45 deg angle. Never had "slippage" that I can remember.
Biggest pro with wood over plastic is weight capacity - I just don't worry about the boards cracking or collapsing.
Biggest con with wood is weight and bulk - the plastic Lego-like blocks are so light and so convenient with how they stack together.
Which is why I also have the Lego-like blocks. I use them as needed when leveling.
But.... I actually use them more as bases for the stabilizing jacks, and also to level things like maybe a picnic table and our grill.
The plastic blocks are quite versatile. So I have both wood and plastic.
2021 F150 2.7
wanderingbob
monticeeo, fla
Posted: 09/02/22 05:53am Link  |  Quote  |  Print  |  Notify Moderator
Wood , 2x6 or 2x8s . Plastic is for toys and water bottles !
mleekamp
Washington, IL
Posted: 09/02/22 06:42am Link  |  Quote  |  Print  |  Notify Moderator
I've used both and carry both. Had some treated planks left over from a deck build some 12 years ago. Cut them into nice squares and use them all the time. I also use the plastic ones too. As stated by others, plastic is light and less bulky, wood is. Both work and if you can, maybe use both.
ReneeG
Meridian, Idaho
Posted: 09/02/22 06:56am Link  |  Quote  |  Print  |  Notify Moderator
Our fifth wheel is a little over 13k and we use the lego like leveling blocks and have had no problems with them shattering. We also have those Anderson curved levelers you back up into and stop when you're level, but don't use them as much as the linking ones.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
spoon059
Just north of D.C.
Posted: 09/02/22 08:01am Link  |  Quote  |  Print  |  Notify Moderator
Blocks of wood worked jsut fine for us for 12 years. Didn't have any problems with slipping. I had 2 pieces of 2x8, slightly longer than my wheelbase and 1 piece of 3/4". Made it reasonably accurate side to side.
We got some Anderson leveler style last year and love them. They are so much easier to simply dial in the exact height, no guessing. Much smaller and easier to store than a piece of 2x8.
2015 Ram CTD
2015 Jayco 29QBS
MitchF150
Puyallup, WA
Posted: 09/02/22 09:37am Link  |  Quote  |  Print  |  Notify Moderator
I use 2x6 boards cut to around 18".. Carry 6 of them. I nailed 'handles' on them (scrap romex wire)
I have had some 'split' on me due to the grain, but for the most part, they have worked for me going on 20 years.. [emoticon]
I would not use them in this manner however... [emoticon]
