RV.Net Open Roads Forum: Fifth-Wheels: No power
 > No power
Candy22
Alabama
Posted: 09/02/22 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
Hi I have a big horn 2008 5th wheel. Smy2 slide outs refrigerator and kitchen plug is not working does anyone know what it could be?
LadyRVer
Posted: 09/02/22 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
Worth a try... reset GFI.. usually located in bathroom.
HappyKayakers
Somewhere in the USA
Posted: 09/02/22 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
Check underneath the slide. I had a 2006 bighorn and the wire loom would rub against the tires until the wires finally separated.
Joe and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
Campground Tees
stickdog
Somewhere, USA
Posted: 09/02/22 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
Is this a residential refrigerator or gas electric? If residential it should be on a separate decacated outlet and which is also powered by an invertor. Fridge either residential or gas electric will never be the main electric on a GFCI.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
BB_TX
McKinney, Texas
Posted: 09/02/22 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
You could also be missing one of your hot legs of 120 vac power. Are you on 50 amp or 30 amp service?
midnightsadie
ohio
Posted: 09/03/22 04:06am Link  |  Quote  |  Print  |  Notify Moderator
start at the source of power .
ReneeG
Meridian, Idaho
Posted: 09/03/22 10:17am Link  |  Quote  |  Print  |  Notify Moderator
Check the fuses. Is it plugged in or not?
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
joelc
Cedar Point, NC
Posted: 09/03/22 11:22am Link  |  Quote  |  Print  |  Notify Moderator
In addition to the previous suggestions also check to be sure the electric feed wires under the slides are not pinched or cut fro slide movement. I had a like problem with my stove once. The propane lead was pinched shutting off the propane to the stove.
bob213
Fresno, CA
Posted: 09/03/22 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
Did OP leave us? Be nice to get an update so we can throw more ideas out there.
ReneeG
Meridian, Idaho
Posted: 09/04/22 09:31am Link  |  Quote  |  Print  |  Notify Moderator
He may be busy trying all the ideas.
 > No power
