RV.Net Open Roads Forum: Fifth-Wheels: Trailer sway milestone 377mb
 > Trailer sway milestone 377mb
GMH
Canada
Posted: 09/05/22 09:00am Link  |  Print  |  Notify Moderator
fowlthing wrote:
2020 Model. Pulling with 2021 Ram 2500 Diesel. Have 3000 miles plus with no issues.
Without checking specs, that sounds like WAY too much trailer for that truck! I see you used to have an F350? Did the issue just start after changing trucks?
Oops….I see you have another thread on the topic here:
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/30358297.cfm
* This post was edited 09/05/22 09:08am by GMH *
joebedford
Sheltering at home
Posted: 09/05/22 09:32am Link  |  Print  |  Notify Moderator
Whenever I hear someone complaining about a towing problem with a BIG 5er with a 3/4 ton, I immediately think OVERLOAD. You're so close (over?) the limits that the difference full tanks can make over empty tanks is enough to make it sway.
blt2ski
Kirkland, Wa
Posted: 09/05/22 02:59pm Link  |  Print  |  Notify Moderator
You put two new tires on rear axle?!? If truck or trailer? I would start with those new tires.
If on the truck, are they softer sidewalks than older tires, different tread patter, brand front vs rear, are rear tires inflated correctly. Some tire don't track well until they have 300-500 Mile's, ie broken in.
Marty
2014 Chevy 1500 Dual cab 4x4
fowlthing
Roger, AR
Posted: 09/05/22 04:59pm Link  |  Print  |  Notify Moderator
put two new tires on the rear axle of the trailer. thanks for your thoughts
2017 Ford 350 SRW
Grand Design Solitude 375RES
may switch to a Ram
fj12ryder
Platte City, MO
Posted: 09/05/22 08:45pm Link  |  Print  |  Notify Moderator
Is the trailer level, nose high, or nose low?
Howard and Peggy
"Don't Panic"
blt2ski
Kirkland, Wa
Posted: 09/05/22 10:03pm Link  |  Print  |  Notify Moderator
Assuming the first 3000 Mike's were with the Ram, you changed out rear tires of trailer, then things starting handling different.....start here! For all the same reasons I gave fire truck.
Marty
fowlthing
Roger, AR
Posted: 09/06/22 05:45am Link  |  Print  |  Notify Moderator
No. Changed the tires after it started as a possible solution
fowlthing
Roger, AR
Posted: 09/06/22 05:47am Link  |  Print  |  Notify Moderator
Trailer is level. Have tried raising and lowering the pin in the truck. Didn’t help
TXiceman
Full Time RVer
Posted: 09/06/22 10:38am Link  |  Print  |  Notify Moderator
Have you weighed the truck and trailer when loaded for travel to see where you are on weights and weight limits. With this information, make sure the truck and trailer are level and tire pressures are correct for the loads.
Without this information, everyone is shooting in the wind in the dark.
Ken
* This post was edited 09/06/22 06:31pm by an administrator/moderator *
Amateur Radio Operator.
joebedford
Sheltering at home
Posted: 09/06/22 11:15am Link  |  Print  |  Notify Moderator
"Have you weighed the truck and trailer when loaded for travel"
I'm guessing that OP has not responded to any of the questions about the weight that weight is in fact the problem.
