RV.Net Open Roads Forum: Fifth-Wheels: Trailer sway milestone 377mb
 > Trailer sway milestone 377mb
fowlthing
Roger, AR
Posted: 09/06/22 11:56am Link  |  Print  |  Notify Moderator
Have not weighed yet. But load has not changed in 3000 miles of towing. Will weigh and post back
2017 Ford 350 SRW
Grand Design Solitude 375RES
may switch to a Ram
TXiceman
Full Time RVer
Posted: 09/06/22 03:08pm Link  |  Print  |  Notify Moderator
joebedford wrote:
"Have you weighed the truck and trailer when loaded for travel"
I'm guessing that OP has not responded to any of the questions about the weight that weight is in fact the problem.
I am thinking he does not want to know how bad off he really is on the truck. But ignoring the issue does not make it any better.
We have all seen people posting that keep looking for someone to tell them that all is fine, just add air bags and truck on.
Ken
Amateur Radio Operator.
fowlthing
Roger, AR
Posted: 09/06/22 03:26pm Link  |  Print  |  Notify Moderator
That is not true. With the holiday etc... haven't had time to weigh the camper and trailer.. it seems something has broken since it sways at such low speeds and worse uphill. And the truck is handling weird unloaded.
Forums like this help because it can point to look in places that are not obvious. This thread is only a few days old... started it on a trip out of town. And I have responded to the weight issue as best I can at this time.
shadows4
Kansas City, Mo
Posted: 09/06/22 04:48pm Link  |  Print  |  Notify Moderator
I would start here. Off hand, I think you should have kept the F350 but I am biased.
2003 4X4 F350,CC,SB,Lariat,7.3L diesel, 219,000 miles
2015 Coachmen Chapparal 324 TSRK
B&W Patriot 16K hitch.
fj12ryder
Platte City, MO
Posted: 09/06/22 07:11pm Link  |  Print  |  Notify Moderator
I wonder if there isn't an issue with 5th wheel overhang structure. You wouldn't be able to easily see a problem, but if some of the reinforcing is cracked or broken, it might lead to sway issues.
Howard and Peggy
"Don't Panic"
blofgren
Surrey, B.C.
Posted: 09/06/22 09:30pm Link  |  Print  |  Notify Moderator
afidel wrote:
Fisherman wrote:
Possibly a broken spring on the trailer.
That's my vote, or spring perch. I'd investigate everything in the running gear including running each wheel up a ramp to see how the suspension and equalizer reacts.
This is exactly how my trailer was acting when some welds on the insufficient side to side braces between the frame broke. It was so unstable from side to side it was scary to pull and I could see the axles moving from side to side when turning corners on the highway.
I had a great fabricator install 3 - 6"x4" structural steel tubes welded between all 3 sets of spring perches and he reinforced them with 2" square steel tubes up to the frame in 6 spots complete with large square pads welded to the frame. He did a great job, and cinched the trailer corner to corner with come alongs to ensure that it was perfectly square before starting. The trailer is super stable now and tows better than it did when I bought it.
OP, check your spring perches, frame, and springs, etc. I would bet that something is broken and causing this issue. Please let us know what you find.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
ford truck guy
Pennsylvania
Posted: 09/07/22 05:43am Link  |  Print  |  Notify Moderator
^^ BUT, The OP stated that his truck is handling weird UNLOAED now as well....
I know he is overweight, but that would not effect the empty ride.. Unless he broke something ?? [emoticon]
* This post was edited 09/07/22 07:35am by ford truck guy *
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
garyp4951
TN
Posted: 09/07/22 07:19am Link  |  Print  |  Notify Moderator
I would check the front and rear sway bar mounts on the truck.
MFL
Midwest
Posted: 09/07/22 08:18am Link  |  Print  |  Notify Moderator
For sure!! If empty truck is not right, likely that the issue is there, and should be easier to diagnose.
Could even be a tire, broken belt, etc?
Jerry
BarneyS
S.E. Lower Michigan
Posted: 09/09/22 06:51am Link  |  Print  |  Notify Moderator
Please see any new replies to your topic here. This thread is closed.
barney
