RV.Net Open Roads Forum: Fifth-Wheels: Trailer sway issies
 > Trailer sway issies
nickthehunter
Southgate, MI
Posted: 09/03/22 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have something really heavy loaded behind the axles of the trailer?
GIB2
Welland
Posted: 09/03/22 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
You mentioned all the suspension I'd be looking on top of pin box to make sure no welds to the trailer frame have broken . The weld on our fifth wheel are less than desirable although they never broke. Costs nothing to look.
MFL
Midwest
Posted: 09/03/22 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
^OP has not responded to several asking about "what hitch using"? If OP is using some type of gooseneck adapter to save hitch wt, a broken frame/weld could be the sudden cause of problem.
Not as likely if using a conventional FW hitch.
Jerry
* This post was edited 09/03/22 04:12pm by MFL *
TXiceman
Full Time RVer
Posted: 09/03/22 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
I addition to being under trucked, that model Ram 2500 has rear coil springs. This is known to be less stable than a leaf string truck.
That model trailer has a rear basement (under the living area). If this is loaded too heavily, it will lighten the pin weight which can lead to poor handling.
Ken
Amateur Radio Operator.
Cummins12V98
on the road
Posted: 09/04/22 07:44am Link  |  Quote  |  Print  |  Notify Moderator
If Icemans numbers are what the OP is towing he is WAYYYYYY out of his league with any 2500 SRW.
Load up, hit the CAT Scales and report back. Also let us know who told you this combo "will tow just fine" !!!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
fowlthing
Roger, AR
Posted: 09/04/22 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Using an Anderson hitch. And this model does not have the basement I have seen it but this Milestone does not have it. Thanks for the info. No weight changes from the first 3000 miles of towing. But something must be broke somewhere.
Have not checked the springs on the truck yet. Other springs and axles to pin box are the same.
Thanks for the help.
2017 Ford 350 SRW
Grand Design Solitude 375RES
may switch to a Ram
Flan
NE
Posted: 09/04/22 09:33am Link  |  Quote  |  Print  |  Notify Moderator
Take a look at the sway bar, make sure it isn’t broken or missing bolts where it attaches to the axle.
Heartland Prowler 27LX
19 Ram CTD 2500
fowlthing
Roger, AR
Posted: 09/04/22 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
Will check the truck for a broken spring or sway bar. Thanks for the input from everyone
Cummins12V98
on the road
Posted: 09/05/22 09:54am Link  |  Quote  |  Print  |  Notify Moderator
Head in sand syndrome!!!
opnspaces
San Diego Ca
Posted: 09/05/22 11:05am Link  |  Quote  |  Print  |  Notify Moderator
I keep thinking you have something broken on the trailer not on the truck. Can you maybe have somebody drive near you around 30 mph and watch the wheels when you hit a bump. Maybe get a few friends to follow, one driving the follow car and one filming on their phone for review later.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
