RV.Net Open Roads Forum: Fifth-Wheels: Trailer sway issies
 > Trailer sway issies
fowlthing
Roger, AR
Posted: 09/05/22 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks..I agree having someone watch in another vehicle is a great idea. I don't see any bolts missing or loose on the sway bar..on the truck.
Thanks for all the input.
2017 Ford 350 SRW
Grand Design Solitude 375RES
may switch to a Ram
valhalla360
No paticular place.
Posted: 09/05/22 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
10 pounds of sand in a 5 pound bag by the looks of it.
Maybe see if a buddy with a 1 ton dually can pull it and if they have the same issue. I'm betting the issue disappears.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Cummins12V98
on the road
Posted: 09/07/22 09:28am Link  |  Quote  |  Print  |  Notify Moderator
Why are you not looking at the FACT you have too much **** trailer for that truck as the cause???? WHY????????????? did you go from a 350 to a 2500???????????
Pulling with 2021 Ram 2500 Diesel
UVW 14200 lbs
GVWR 16800 lbs
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
fowlthing
Roger, AR
Posted: 09/07/22 09:56am Link  |  Quote  |  Print  |  Notify Moderator
The ram set up is my brothers...I am posting asking for him.. I have the 350,
TXiceman
Full Time RVer
Posted: 09/07/22 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
You have to remember that Ram in their great wisdom, went to coil springs on the back of the 2500 like they did on the 1500. So far, the coil springs do not handle weight as well as the leaf springs.
Ken
Amateur Radio Operator.
fowlthing
Roger, AR
Posted: 09/07/22 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
Towed with a friends F250. No problems. So the truck is the culprit. Tires are worn. Will get to dealership for full check up
Cummins12V98
on the road
Posted: 09/07/22 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
You simply are NOT listening to FACTS. Too much RV for any 250/2500 no matter how you slice it!
Culprit??? Not hardly as you are asking it to do something that it simply can't. Waste all the money they want but the truck is NOT the issue.
fj12ryder
Platte City, MO
Posted: 09/08/22 07:42am Link  |  Quote  |  Print  |  Notify Moderator
Is the truck lifted? Or aftermarket tires?
Howard and Peggy
"Don't Panic"
GMH
Canada
Posted: 09/08/22 07:57am Link  |  Quote  |  Print  |  Notify Moderator
The truck may very well have damage that is causing the swaying….but even if the truck is repaired and brought up to spec, it is still not near enough truck for that trailer. Towing that trailer with that truck is an accident waiting to happen, and probably illegal.
OP: Please convince your brother to get a 350 dually or a smaller trailer.
fowlthing
Roger, AR
Posted: 09/08/22 08:56am Link  |  Quote  |  Print  |  Notify Moderator
truck is not lifted and tires are original from factory
