wogg
meid
![[image]](https://i.imgur.com/jlykHPJl.jpg )
Click For Full-Size Image.![[image]](https://i.imgur.com/G69npB3l.jpg )
Click For Full-Size Image.![[image]](https://i.imgur.com/3D9wf8il.jpg )
wogg
meid
Picture #1 Is the head Unit mounted on wall above the Kitchen slide and the tube off to the right is the condensation drain. The left tube is the freon and electrical.
Picture #2 is the continuation of the electrical. Goes through cabinet and out back wall.
Picture #3 is the condenser that is mounted to a rack that was mounted to the trailer frame so there would be no vibration to disturb the line set.
I also use a small floor fan to help circulate the air around the trailer. Any other questions, please feel free to ask.
spoon059
Just north of D.C.
Cool, thanks for posting! I've got a lot of questions since I saw one installed last!
What size unit is that?
Do you know how many amps it pulls when its running?
Does it cool down your camper faster than the roof AC unit did?
With doors open, does the single head distribute cool air all the way front and back?
With doors closed, does it get stuffy in the bedroom?
Have you tried running the overhead ducted vent fan to move air around?
Finally, what did it cost? Head unit, any installation costs, getting the rack made/mounted.
2015 Ram CTD
2015 Jayco 29QBS
LMHS
NM
jjj wrote: The only problem I have is my fiver has 3 rooms, a small rear room, main living then the front bedroom. Not sure how good cool air
flow would work getting to all areas.
You might think about a "room-to-room" fan. We had installed one in a house to pull heat off the exposed stack on a wood stove and blow the air into the bedroom that backed up against the brick woodstove niche. They are fairly common. If you don't want to mess with the wiring for a fan forced, you can easily just make a cutout thru the wall near the ceiling and cover the hole with vent covers on each side of the wall. Vent covers (or floor register vents) come in several shapes and finishes. You can even get pretty decorative ones. It would do the same thing that transoms did, allow air flow when the door to a room was closed. I've seen them mounted on solid and hollow core doors too.
wogg
meid
spoon059 wrote: Cool, thanks for posting! I've got a lot of questions since I saw one installed last!
1. It is a 12000 BTU unit. I don't know the amps but it will run on a 2000 watt generator without any problems.
2. It cools down the RV in about 30 min as where the roof top would never get it to a comfortable temp.
3. Like i said I use a floor fan to move the air around and it will keep the entire RV very cool.
4. With the bedroom door closed I do need to run the bedroom A/C on low if it is very hot outside.
5. I don't have the old A/C so there is no fan for the ducted ceiling. If you do have that it would work nicely.
6. The A/C was about $850.00. Depending on how far the head unit is from the condenser you might need to buy a longer line set. I did the install myself with the help of my son-in-law who is a HVAC tech. The rack was put on before I had this A/C planned. It cost $600.00 at a local welding shop.
I hope this helps. If not ask more questions if needed.
jjj
Lancaster,Ca.U.S.A.
WOGG,thanks for the reply and the pictures. Very cool.
2002 F-350 Crew-Cab Dually
V-10-4.30 gears Mag-Hytec diff.cover
w/Amsoil-6.0 trans cooler Curt Q5 20K hitch & bedsaver
2005 Keystone Challenger 34TBH-Fifth Airbourn
spoon059
Just north of D.C.
Awesome wogg,thanks!
