RV.Net Open Roads Forum: Running Two ACs on Gennie - Shutting down
 > Running Two ACs on Gennie - Shutting down
Lakejumper
Northern California
Posted: 09/03/22 10:38pm Link  |  Quote  |  Print  |  Notify Moderator
Hi, I’m running my 5500 Watt Onan gennie with two ACs on while driving due to very hot weather. They both ran for several hours and all of a sudden they shut down and the control panel beeped with the gennie still running. It eventually reset itself. This happened several times. We had a full tank of gas. I had the gennie serviced recently. Why is this happening?
Lakejumper
2016 Winnebago Vista LX 30T
2012 Chevy Equinox
pianotuna
Regina, SK, Canada
Posted: 09/04/22 10:14am Link  |  Quote  |  Print  |  Notify Moderator
It may be that the generator is overheating and shutting off to protect itself.
Regards, Don
way2roll
Wilmington NC
Posted: 09/04/22 11:01am Link  |  Quote  |  Print  |  Notify Moderator
That's what I thought too but the OP said that the AC's shut down and the genny kept running?
To the OP, when it happens you need to get the code from the genny and it will tell you what the problem is.
2023 FR Sunseeker 2400B MBS
Yankee Clipper
Cairo, GA
Posted: 09/04/22 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
There are a few auto-shut-off features, thermal, and low-oil are the most common tripwires. IN the heat, the fuel can vapor-lock. Check the airflow over the genny, another concern.
Yankee Clipper
2014 Winnebago Sightseer 33C on Ford F53 6.8l V10
2014 Honda CRV 4 down toad/Roadmaster Falcon2 with EvenBrake
TireMinder TPMS,Tiger, the Little Big Man minidachshund,
Rosey the minidachshund resident Princess-in-Chief
time2roll
Posted: 09/04/22 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
Control panel beeped? Is that an energy management panel? Could it be a load shed due to the water heater electric element coming on?
Did both A/C shut down together?
Self reset does seem odd unless something sensed an overheat condition.
675w Solar pictures back up
Lakejumper
Northern California
Posted: 09/04/22 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies. The gennie kept running. I think the time2roll has the answer. It seemed like a load shed. The water heater was off and the fridge was on propane. I also thought that since I had the AC fan on high, both units may have coincidentally started at the same time so one shut down. It happened about three times during the last part of our trip during the hottest part of the day. We were also climbing at high elevation over 6000 feet. Perhaps the gennie surged. I’ll look at the manual.
Lakejumper
Northern California
Posted: 09/04/22 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
I think that I know what happened. I failed to mention that I was in the high Sierra mountains at about 6000-7200 feet when this occurred. I believe that the Power Management System did a “load shed”. The manual states that the AC’s use at least 2400 watts when starting up. I have a 15k btu in the front and either a 13.5k or 11k in the rear. The manual states that the 5500watt gennie loses 3.5% power for every 1000 feet gain in elevation. Thus, I was losing about 23% of the gennie power. It couldn’t keep up with the ACs. This has been a good lesson.
