RV.Net Open Roads Forum: Fifth-Wheels: 5th Wheel vs. Gooseneck
 > 5th Wheel vs. Gooseneck
engine31
Louisville, Kentucky. USA
Posted: 09/04/22 08:39am Link  |  Quote  |  Print  |  Notify Moderator
Hi all just a quick question we are about to embark on the purchase of a 5th wheel which will be a new adventure for us. We have towed everything small to large but all bumper pulls. At a sales lot yesterday the guy said we will put a gooseneck in your bed. I did a little bit of research but decided to come here to seek out the best advice.
Thanks
phillyg
SWFL
Posted: 09/04/22 09:42am Link  |  Quote  |  Print  |  Notify Moderator
Make sure the RV mfgr. allows a gooseneck without voiding your frame warranty.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
MFL
Midwest
Posted: 09/04/22 10:57am Link  |  Quote  |  Print  |  Notify Moderator
Asking this type question will get best replies in the fifth wheel section of the forum.
While you aren't giving enough info, as to what your TV is, here is some things you might add.
What year, make, and model is your tow vehicle? What size, length and GVWR is the fifth wheel you are considering? Why do you want a gooseneck ball installed in the bed, and what hitch are you considering?
Using a gooseneck adapter is not usually the best choice, and will void your warranty on many new FWs.
Jerry
BB_TX
McKinney, Texas
Posted: 09/04/22 11:14am Link  |  Quote  |  Print  |  Notify Moderator
If you are buying new, Lippert frames approve a Goosebox adapter (has shock absorbers and air bag) but not rigid adapters.
Many people prefer gooseneck hitches, some because they are used to them from hauling stock or construction trailers. They may be a little harder for you to hook up as it may hard to see the ball in the bottom of the bed. And being a ball it has to be lined up pretty close. A 5th wheel hitch is more forgiving. And in general a gooseneck, being a ball hitch, requires safety chains similar to a bumper hitch.
camp-n-family
London, Ontario
Posted: 09/04/22 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
You can put a goose neck hitch in the bed and use a hitch on it like the b&w companion or an Anderson. Most rv pin boxes aren’t strong enough for a goose neck adapter and manufacturer warranties won’t support it.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
JIMNLIN
Oklahoma
Posted: 09/04/22 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
Depends what is meant by a gooseneck in the bed. More than one style of GN type hook ups out here for a 5th wheel type rv trailer..
Need more onfo on what the sales guy was talking about.
Thermoguy
Graham, WA
Posted: 09/05/22 09:59am Link  |  Quote  |  Print  |  Notify Moderator
My truck has a B&W turn over ball - essentially a gooseneck hitch. To haul my 5th wheel, I have a B&W companion, that uses the gooseneck hitch to attach to the truck. So, depending on the conversation - did you say you wanted a hitch without rails or to keep your bed clean when not using?
What is your truck?
C Schomer
Pueblo West, Co.
Posted: 09/05/22 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
I built my RV bed for fifth wheel hitch and gooseneck ball. When I had both kinds of trailers I was constantly switching back-and-forth so I put a king pin post on my gooseneck trailer so the fifth wheel hitch worked for both. That was the best of both worlds… The easiest hitching for both trailers and no gooseneck adapter problem on the fifth wheel RV.
TXiceman
Full Time RVer
Posted: 09/06/22 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
Goose neck trailers are specifically built to be pulled by a goose neck ball. Adding an after-market adapter to a 5th wheel trailer does not make it suitable to tow from a goose neck ball.
Ken
Amateur Radio Operator.
spoon059
Just north of D.C.
Posted: 09/06/22 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
Ken
Reese Goosebox
2015 Ram CTD
2015 Jayco 29QBS
