RV.Net Open Roads Forum: Tech Issues: Onan 3.6 won't crank
 > Onan 3.6 won't crank
bounder39zman
SC
Posted: 09/18/22 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
need to know "spec" letter, and serial no. of gen to know which control system you have. In any case, oil level has NO EFFECT on starter and cranking operation. Older spec units did have low oil level cut out switch, but did not prevent starter operation. And...these units dont hold much oil (imho) and should be run at full crankcase level for maximum engine protection. Lots of useful info on internet,,,lots of B.S. too
guy48065
SE Michigan
Posted: 09/19/22 05:36am Link  |  Quote  |  Print  |  Notify Moderator
Spec: R
SN: B170148513
05 Durango Hemi
2010 Neo all-aluminum 7x20 CH
Gary45
Oshawa, Ontario, Canada
Posted: 09/20/22 10:10am Link  |  Quote  |  Print  |  Notify Moderator
There is more than one type 3.6, the full model number would help.
guy48065
SE Michigan
Posted: 09/20/22 11:26am Link  |  Quote  |  Print  |  Notify Moderator
Ok here's the label:
Gary45
Posted: 09/20/22 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
This url will take you to a page for your unit, there is a download section where manuals are, in the operator manual section 4 page 21 there appears to only be an AC breaker. This manual does not have a wiring diagram unfortunately. I did find another manual with a wiring diagram, it showed 12 volts going directly to control board, I'll find it again and post link however while it's for a 3.6 not exactly the same model.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwi4x9r9oKT6AhVIhIkEHY01CR8QFnoECBAQAQ&url=https%3A%2F%2Fwww.coloradostandby.com%2Fcummins-onan-3-6-ky-fa-26120-rv-or-commercial-generator-set-rv-qg-3600-lp&usg=AOvVaw2EMtr_TesUTaxXFTnvSi-u
guy48065
SE Michigan
Posted: 09/20/22 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
The Install Manual there for Spec "R" does include a wiring diagram and it does have one difference compared to all the other earlier-Spec manuals I've downloaded: IT DOESN'T SHOW ANY FUSES.
Really I can't recall the last time I saw a product that connects DIRECTLY to a vehicle battery that didn't have a fuse internal or in-line for component and fire protection.
Very strange. Very stupid, IMO.
Gary45
Posted: 09/20/22 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
On the wiring diagram it has the jack pin out where you could see if you have 12 volts at the control board. It is kind of strange, no fuse, you might need the control board. If it was mine I'd be inclined when all figured out to add a fuse.
