RV.Net Open Roads Forum: First place to look re. where water got in to our TT
 > First place to look re. where water got in to our TT
JBarca
Radnor, Ohio, USA
Posted: 09/06/22 10:13pm Link  |  Quote  |  Print  |  Notify Moderator
Hi trailernovice,
Your welcome and glad the info helped. There are high odds, the windows are the leak source due to the puddling inside the living space, but there are many other ways too. If you find the windows are not the issue, then come back to us. There are ways to back into where other leaks can get into the living space.
Ideally you can test what you have now, before making drain cleaning/adjusting to create a baseline. Then later test again after the cleaning to see if you actually helped the problem. This adds support to you found the issue. If there is no change in drain flow before and after, then one needs to dig deeper until it all adds up.
Let us know how you make out.
John
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
BarneyS
S.E. Lower Michigan
Posted: 09/12/22 08:01am Link  |  Quote  |  Print  |  Notify Moderator
In addition to the excellent info from John, I would be checking the caulking under the clearance light base plates. Also the weep holes in the lens covers.
Barney
Not towing now.
