RV.Net Open Roads Forum: Fifth-Wheels: Solitude leaning to one side.
 > Solitude leaning to one side.
klr650goldwing
minnesota
Posted: 09/05/22 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
Our Solitude 369RL is leaning to the left. We are loaded up for a month long journey and our pantry, frig, Island, stove etc. is all located on that side of the 5er. We are 3 inches low on that side. Springs look okay. Is it possible to put air bags on a trailer?
2014 Grand Design Solitude 369RL
2017 F350 6.7 DRW CC LB 4X4
2012 Mercedes E550
2010 Honda Civic
2009 Saab 93 Aero Convertible
2004 Honda Goldwing GL1800
2004 Kawasaki KLR650
1966 Honda 305 Dream
CA Traveler
The Western States
Posted: 09/05/22 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
If everything in the suspension is good then go on the trip as 3" is acceptable for most refers. Level at the site if desired and resolve when you return.
2014 Grand Cherokee Overland
Bob
pianotuna
Regina, SK, Canada
Posted: 09/05/22 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
Call a mobile rv mechanic.
Is the unit new to you?
If not did it lean before this?
Regards, Don
fj12ryder
Platte City, MO
Posted: 09/05/22 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
If you're 3 inches low on one side, I find it hard to believe your springs look okay. Three inches is a lot, and if your springs aren't flat, then you have some problems somewhere. A decent spring should have about 3 inches of travel. If you can post some pictures of the springs on the low side. I'll bet they look like "w's".
Grand Design tends to put springs that just barely can carry the load. Replacing springs is a pretty common practice. I just replaced mine on my 2019 Momentum.
Howard and Peggy
"Don't Panic"
time2roll
Posted: 09/05/22 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
x2 on springs. Plan to replace all with 10%-20% higher load rating.
675w Solar pictures back up
bucky
Raleigh metro
Posted: 09/06/22 03:32am Link  |  Quote  |  Print  |  Notify Moderator
Are the slides out when it is leaning or does that make any difference?
Puma 30RKSS
southernsky
Ponchatoula La.
Posted: 09/06/22 05:07am Link  |  Quote  |  Print  |  Notify Moderator
Don't own our 369 anymore, got rid of it a couple mths ago, but changed the springs from 3500 to 4000 lbs. Also changed out the equalizer to Dexter and installed disk brakes.
2022 Renegade Super C
2020 Ford Ranger 4x4 Sport
JIMNLIN
Oklahoma
Posted: 09/06/22 05:19am Link  |  Quote  |  Print  |  Notify Moderator
Sometimes when the trailers leaf spring suspension is lifted off the ground the equalizer bar side links can flip causing this issue.
Leaf springs can settle over times especially when carrying loads at max or close to max.
A big rig trailer repair shop near you can find your trailers suspension issues and offer a fix.
GIB2
Welland
Posted: 09/06/22 09:59am Link  |  Quote  |  Print  |  Notify Moderator
You can spend $1000.00 dollars here and $1000.00 there or take it to Mor/yde and put on their independent suspension and Disc brakes and go and enjoy the trailer. These other band-aids is like peeing into the wind.
fj12ryder
Platte City, MO
Posted: 09/06/22 11:01am Link  |  Quote  |  Print  |  Notify Moderator
"These other band-aids is like peeing into the wind."
Oh bosh. Spending over $5,000 is not necessary to have an excellent pulling trailer.
