RV.Net Open Roads Forum: Do you know what brand/model this bed camper is?
 > Do you know what brand/model this bed camper is?
RookieCamperGirl
26201
Posted: 09/12/22 10:59am Link  |  Quote  |  Print  |  Notify Moderator
Hello everyone! I'm new to the camper life, and I found this old shell that someone had thrown away and knew that it had potential. It has major water and animal damage to the floor from being left on the ground (I'm assuming), so I'm currently rebuilding the base frame for it. Does anyone know what brand/make/model this may be? I haven't been able to find a logo or serial/VIN number anywhere on it. If you have any ideas, that would be extremely helpful as I try to restore it! I'll be ripping the bottom off and cleaning the inside in preparation for the new base, so that's why it's sitting on the door end. It has two sliding windows, one solid window toward the cab, and a main door on the back. It is a non-cabover camper, and had some 1978 travel books inside of it when I picked it up.
Southern California :(
Posted: 09/12/22 11:44am Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately I believe you'll find more repair/replacement work than you anticipate. I hope I'm wrong.
Posted: 09/12/22 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
There is no info you could gain to help you do whatever you're going to do with that by knowing the make and model.
JoeChiOhki
Sauvie Island, OR
Posted: 09/12/22 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
It could be any number of them, including a self-built Glen-L Truck cap.
My Blog - The Journey of the Redneck Express
CB Channel 17 Redneck Express
'2006 Heartland BigHorn 3400RL
RookieCamperGirl
26201
Posted: 09/13/22 11:05am Link  |  Quote  |  Print  |  Notify Moderator
Oh you're not wrong, there is quite a bit to do. The only things that are still good (but need to be cleaned up/polished/repainted) are the actual shell exterior and the windows.
RookieCamperGirl
26201
Posted: 09/13/22 11:09am Link  |  Quote  |  Print  |  Notify Moderator
Knowing the make and model is more for my personal knowledge of it, but since the base was obviously homemade it would've been helpful to try and find original plans for this particular shell.
RookieCamperGirl
26201
Posted: 09/13/22 11:12am Link  |  Quote  |  Print  |  Notify Moderator
That's still very helpful, thank you! I know nothing about campers, I just have construction/electrician experience and am taking a stab at something new. Plus I think it will be a great addition to my spring trout fishing trips. But I just did a quick search on Gen-L Truck Caps, and the construction on the frame looks extremely similar so thank you!
RookieCamperGirl
26201
Posted: 09/13/22 11:22am Link  |  Quote  |  Print  |  Notify Moderator
Just an update on the camper:
I've removed the entire base/floor/walls/bed frame. The shell itself is intact, but the insulation needs to be replaced and new walls put in. I have the base frame built for the floor and the walls, as well as the a new frame for the single bed, but I'm going to rewire the whole thing while I have it gutted. The shell is watertight, but I'm grouting the windows to make sure it's sealed. The door was destroyed, obviously someone tried to break in at some point, so I have plans for a newer more modern styled-door.
jaycocreek
Idaho
Posted: 09/13/22 11:49am Link  |  Quote  |  Print  |  Notify Moderator
Those were quite common back in the day..Some of the local manufacturers like Security industries and Kit campers were ones we had...Easy to make an overnighter out of...
Lance 9.6
400 watts solar mounted/200 watts portable
500ah Lifep04
joerg68
St. Ingbert, Germany
Posted: 09/13/22 11:58am Link  |  Quote  |  Print  |  Notify Moderator
The camper is a conventional wood frame model with metal siding. I would guess it was built some time between 1965 and 1980. They are simple to build, and there were literally dozens of smallish manufacturers around, most of which no longer exist - and in the time before the internet.
The good news is: this is not rocket science once you understand the basic construction principles.
There are specialized rv junkyards and many of the more exotic parts like siding are available as well.
There are also a number of people around who restore old rvs as a hobby. Maybe one of them chimes in.
It looks like a fun project and I wish you success - and a lot of fun with your little camper!
