RV.Net Open Roads Forum: 2002 Pace Arrow Kwikee 2-Step Arm Linkage (A) Broke
 > 2002 Pace Arrow Kwikee 2-Step Arm Linkage (A) Broke
cyberham
Sunshine Coast, BC
Posted: 09/12/22 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
My Kwikee steps were working fine until one day the A arm linkage that connects the motor to the actual steps broke in half. So the only item I need to replace is the arm linkage. The motor and all else work fine.
But I can't find this pre-IMGL A arm linkage anywhere. It's replacement number is LC379649. My Kwikee steps are from the days when the company was located in Cottage Grove, Oregon.
Any tips?
enblethen
Moses Lake, WA
Posted: 09/12/22 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
Try Colaw
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
cyberham
Sunshine Coast, BC
Posted: 09/12/22 10:55pm Link  |  Quote  |  Print  |  Notify Moderator
I sent Colaw a request. Thanks.
eHoefler
ozark mountains
Posted: 09/13/22 05:42am Link  |  Quote  |  Print  |  Notify Moderator
Have it welded
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
cyberham
Sunshine Coast, BC
Posted: 09/13/22 09:19am Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately, Colaw replied they didn't have. The material the link is made of is perhaps "pot metal" which I've heard can't be welded. I may just try the newer A linkage (379160) and also get a new motor (676061) which is supposed to be necessary to be compatible with the new linkage assembly.
enblethen
Moses Lake, WA
Posted: 09/13/22 09:35am Link  |  Quote  |  Print  |  Notify Moderator
Just checked the one in my garage. The linkage has strange connection to the body. Mine looks similar to this!Linkage
enblethen
Moses Lake, WA
Posted: 09/13/22 09:48am Link  |  Quote  |  Print  |  Notify Moderator
Looked harder at mine. The linkage is connect to pivot with what looks like a hot rivet.
Found this on Amazon! Things changed when Kwikee sold out to Lippert!
Amazon
cyberham
Sunshine Coast, BC
Posted: 09/13/22 10:56am Link  |  Quote  |  Print  |  Notify Moderator
Yes, those you found on ebay and amazon are the post-IMGL (Integrated Motor/Gearbox/Linkage) versions and the linkage visually looks like mine. They should work on mine but I will also need to source a new motor if I use those. I may take a chance and get this since the older pre-IMGL version is not to be found.
enblethen
Moses Lake, WA
Posted: 09/13/22 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
Newer models may need the magnetic door switch changed out.
Did quick look. Prices are nearly as much as I paid for complete step at Colaws a few years back. I was at their facility, no freight.
Any salvage yards have MHs in your area?
Thought there was one near Chiliwack
cyberham
Sunshine Coast, BC
Posted: 09/13/22 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
If I make a move to buy, I'll take one step at a time since the repair isn't time sensitive.
I was thinking of a hack....join two camping stakes by chain or rope then thread them through the steps and bang the stakes into the ground. Then the steps are fixed down. To raise the steps only for travel, I could wire the steps up. Very little travel planned in the short term; we'll be mostly fixed through this winter.
No MH salvage on the Sunshine Coast. This is a small community separated by ferry from greater Vancouver and Chilliwack.
