Railronnie
Baton Rouge, LA
We are spending several months at a time in our RV. I have tried numerous ways of keeping personal files. My hanging files jump off the rails while traveling and fall down into any file drawer, file box or file container I have tried. Anyone have a hack for keeping the files ON THE RAILS? I have seen hacks with clips to keep them from sliding, but I want them to STAY ON THE RAILS. Any ideas???
PartyOf Five
Wheaton, IL
The back of our C bounces a lot, even when overloaded. Maybe you can keep the file cabinet in the truck. I've found banker boxes to be a better option, but really going (more) paperless has been the most convenient.
PartyOf5 appreciating our Creator thru the created. 5 yrsL 50k, 49 states & 9 provinces.
May you find Peace in all you endeavor.
SAR Tracker
Central Oregon
Load a hanger-box (like a Bankers Box) with your files, then stand it on end. Put the lid on!
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
opnspaces
San Diego Ca
Trying to think outside the box. Since the hangers have to lift up you need to find a way to prevent them from lifting too high.
My first thought is maybe an appropriately sized piece of plywood that lays flat across the top of the files and fill the gap. When the drawer is closed the files can't jump up to unhook. When the drawer is open just remove and set the piece of plywood on the floor to get it out of the way. Thinking further the plywood probably doesn't even have to be thick enough to fill the gap between the hooks and the top of the cabinet. The weight of the wood alone might be enough to keep the hooks in place.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Second Chance
Wherever...
We use something like this and it keeps the hanging files in place very well during travel:
Hanging file box
If you have a lot of files, you may need several.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
Matt_Colie
Southeast Michigan
I had to move such a box several times. The first time, folders did jump off the rails. Then I packed the top with several layers of bubble wrap and even the box that fell upside down stayed engaged.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
JimK-NY
NY
When I started as a full timer, one of the first steps was to go as nearly paperless as possible. I even bought a small wand style handheld scanner so I could convert any paper files I received to electronic while travelling. My few paper files were stored in interoffice memo envelopes.
valhalla360
No paticular place.
We have a single draw file cabinet for items that can't be paperless. Packing it full seems to work OK.
But as others have said, unless you really need a physical piece of paper (say a truck title or such), avoid it. Non-critical paperwork (receipts, utilities, etc...) we take a picture and save it to a portable hard drive (we do back up the hard drive periodically also).
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
wildtoad
Blythewood, SC
If you have a file box like the one referenced above which has a lid, I would think folding a towel and laying it between the lid and folders would keep the files in place.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
LMHS
NM
I used to use the little skinny bungee cords to keep the files on the hangers in file cabinets when moving. I used one pair of cords over each end of the metal frame.
