RV.Net Open Roads Forum: Travel Trailers: How to re-caulk RV trailer roof?
 > How to re-caulk RV trailer roof?
peterspeter
Ontario, Canada
Posted: 09/14/22 11:22am Link  |  Quote  |  Print  |  Notify Moderator
I'm recaulking my RV trailer. Going well except these heavy lines of something slathered on the roof. When I try to lift, it seems the rubber roof lifts with it. How can this be repaired?
Here is a pic of the roof:
(Moderator edit to show picture)
Is there a good product I can go over this with?
We got the trailer for cheap and the look of the repair isn't as important as making sure it won't leak in the future.
For the smaller caulk lines I'm using thermoplastic caulking that people use for caulking outdoor window trim which is going well.
Thanks in advance!
* This post was edited 09/14/22 05:08pm by an administrator/moderator *
2oldman
NM
Posted: 09/14/22 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
I use Heng's rubber roof seal. Thin, goes on like paint. No leaks. Would cover all that and make it look a lot better.
* This post was edited 09/14/22 01:49pm by 2oldman *
Cambria, California area
Posted: 09/14/22 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
I’m a Heng’s fan too. Never look for, or care about, beauty in an RV roof. Look for recent maintenance.
valhalla360
No paticular place.
Posted: 09/14/22 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
Use RV lapseal and just go over it making sure to cover the edges.
Don't use random non-RV caulk. I'm not sure what you mean by "thermoplastic" but if it contains silicone, you may run into an issue where nothing will stick to it. Or if it contains harsh chemicals, it could damage the rubber roofing.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
katysdad
Virginia
Posted: 09/14/22 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
Not a repair. Original self leveling lap sealant such as DICOR. Unless loose its almost impossible to get off of the rubber without inflicting damage. Just wash roof with a mild detergent and let dry. Recoat all joints, fittings, and hardware with lap sealant for rubber roofs.
Dodge Ram 3500 DRW Diesel
JIMNLIN
Oklahoma
Posted: 09/14/22 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
When applying a self leveling roof sealant over OEM sealant don't make a dam to stop the roof from draining. Big blobs across a area can cause pooling (lake effect) up there ...that ain't good.
If the OEM sealant isn't loose I leave it as is.
My old '97 32' 5er still has OEM sealant (80-90 percent) in most spots on the rubber roof material.
There are some good self leveling sealant brands out here for resealing those loose spots.
schlep1967
Harrisburg, PA
Posted: 09/15/22 05:29am Link  |  Quote  |  Print  |  Notify Moderator
What you are looking at is lap sealant. Here is a link to Amazon where you can buy it Linky or any RV place will have it.Do not use the caulk you have now.
I have removed old lap sealant. On a sunny day you can use a plastic putty knife and patience to get it off. Or even a hair dryer to warm it up.
Make sure the area is clean before applying the new lap sealant. Instructions can be found on the tube.
2021 Chevy Silverado LTZ 3500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide 4500
2oldman
NM
Posted: 09/17/22 11:51am Link  |  Quote  |  Print  |  Notify Moderator
coming back?
Duane4238
North Tonawanda, New York
Posted: 09/21/22 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
I've used the Heng's product but was not impressed. It seemed very thin to me. After 2 years it started to peel-lift. On my most recent trailer, I had a questionable area on my larger slide. After thorough cleaning, I rolled on a product I'd tried at home. It's FlexSeal Liquid. The manufacturer says it's good for EPDM roofing so I gave it a shot. It is very thick stuff, which is what I wanted and I rolled it on nice and thick. It dries into a flexible rubber. I used it 2 years ago and it still looks like new, and the slide roof doesn't leak. I'm going to go around the whole perimeter of the roof with a roller and this stuff to put a new coat of sealant on the edges. It comes in black or white. I used the white. Also comes in a paste you can put on with a putty knife if you have any open areas that need filling.
Duane
fallsrider
Raleigh, NC
Posted: 09/24/22 08:17am Link  |  Quote  |  Print  |  Notify Moderator
I use the Dicor self-leveling lap sealant, as well. It sticks good and lasts. I clean the area first with denatured alcohol.
