PAThwacker
East Stroudsburg, PA
It’s best practice to remove all previous caulk and reapply fresh lap sealant. Also cover front roof trim holder. Leaks from screws also leaks from towing in rain on front seam. If really anal remove roof trim remove butyl tape. Buy new trim, new butyl tape, and new lap sealant.
2015 Keystone Springdale Summerland 257rl
Tow vehicle: 2003 GMC K1500 ext lb
Previous: 14 years of 3 popups and a hybrid tt
trail-explorer
NM
Here's a useful video on Applying Dicor
Vintage465
Prunedale CA.
If I don't like the way something looks or if I need to remove it to replace whatever it is sealing, I use a heat gun(carefully) and an 1-1/2" putty knife that has the edges rounded and doesn't have a sharp edge. It would prolly take 30-40 minutes to remove all that. Then take mineral spirits, or as we used to call it "paint thinner" and a rag to scrub it up. If you want it super clean you can give it a once over with alchohol and a rag before using self leveling roof sealer. I use the one that has the guy smiling at you on the label......can't think of the name.
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
Pbutler97
Midwest
Vintage465 wrote: I use the one that has the guy smiling at you on the label......can't think of the name.
That's Dicor, the smiling guy is Rudy. My wife seen a tube on my workbench and asked why a company would put a creepy looking smiling guy that looks like uncle pervy on a tube of caulking?
Mr. C
SW Virginia, USA
Is there a reason that no one has mentioned using Eternabond over the lap sealant?
2020 Keystone Cougar 26RBS "Pressure Relief 4"
2017 Silverado LTZ 6.2 4x4
MM2 USN 1970-75
USS Canisteo AO-99
USS Miller DE-1091
"Knowledge is good". Emil Faber
BarneyS
S.E. Lower Michigan
Probably because that was not what the OP asked. Quite unusual though I will admit.![awink [emoticon]](http://www.rv.net/sharedcontent/cfb/images/awink.gif)
Barney
Not towing now.
deadticket8
All over
I haven't used Henges, but Ill look for it next time. I use a white roofing compound out of a home improvement store, seems to do the trick.
deadticket8
All over
Also I think mineral spirits is pure. Paint thinner can contain additives like benzene. Good info on "the spruce".
deltabravo
Spokane, WA
Use Dicor Self Leveling Sealant
