RV.Net Open Roads Forum: Class A Motorhomes: Sanitizing your RV water storage tank
 > Sanitizing your RV water storage tank
blazenpm
Home
Posted: 09/15/22 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
All this dialogue on santitizing your water tank gets me to thinking. Due some physical issues, we have not taken our RV out in a while (several months). I have drained my RV water tank twice . I have put 1/4 cup of bleach in it every time I refill it. So my question is: How do yall sanitize you water storage tank. The other question when hooked up to shore facilities i.e. potable water bib. does that water go directly into your water storage tank then to your water faucets or does shore water stay in pipes then go to the faucets in or out of the RV?
CA Traveler
The Western States
Posted: 09/15/22 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
For treated city water no need to do anything. Otherwise for several months add bleach at the beginning only, when leaving drain, refill unless to much taste then drain and refill.
Some hose bibs fill the tank, some don't. Check your owners manual.
2014 Grand Cherokee Overland
Bob
Cambria, California area
Posted: 09/15/22 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
A quarter cup of bleach may well do the job…depending on the overall capacity of the fresh water tank. Four ounces of bleach treats about 25 gallons of fresh water capacity. Bleach is your friend!
Posted: 09/15/22 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Sanitize not only the fresh water tank but the fresh water lines to the kitchen sink, bathroom sink, shower and, yes, the toilet.
SAR Tracker
Central Oregon
Posted: 09/15/22 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
Just filled the tank(s) for 100gals total, in prep for a possible evacuation due to a fire. Between the 2, I added 1.5 oz of 6% bleach (unscented). Well water from my property, run thru a filter in pump house, then another (blue) filter at the end of the hose.
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
TechWriter
Part-Timing Again
Posted: 09/15/22 11:01pm Link  |  Quote  |  Print  |  Notify Moderator
Per NFPA 1192 Standard on RVs, use 1/4 cup bleach per 15 gal of water (50 ppm ratio). So for a 90 gal RV water tank, you would use 1 1/2 cups of bleach. Run the bleached water throughout the RV plumbing, let it stand for 4 hours, then thoroughly flush with fresh water. For a stronger dose (100 ppm), you would use 1/2 cup of bleach per 15 gal water.
If you don't like using bleach, then you can sanitize your tank with Purogene
On the other hand, if you want to sanitize the water, and not the water tank, then you're talking about adding drops of bleach. Here are the EPA's Recommendations.
* This post was edited 09/16/22 09:41am by TechWriter *
2004 - 2010 Part Timer (35’ 2004 National RV Sea Breeze 8341 - Workhorse)
2010 - 2021 Full Timer (41’ 2001 Newmar Mountain Aire 4095 DP - Cummins)
2021 - ??? Part Timer (31’ 2001 National RV Sea View 8311 - Ford)
www.rvSeniorMoments.com
DISH TV for RVs
wildtoad
Blythewood, SC
Posted: 09/16/22 02:51am Link  |  Quote  |  Print  |  Notify Moderator
Hummmm 15 goes into 90 six times. 6 quarters would be one and a half cups.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Bumpyroad
Virginia
Posted: 09/16/22 05:47am Link  |  Quote  |  Print  |  Notify Moderator
It is too early for math quizzes.
bumpy
oldave
Tx
Posted: 09/16/22 07:25am Link  |  Quote  |  Print  |  Notify Moderator
It's modern math!!! You can get any answer you want. [emoticon]
Posted: 09/16/22 09:52am Link  |  Quote  |  Print  |  Notify Moderator
Any time is too early for math.
