RV.Net Open Roads Forum: Travel Trailers: Recommendations? Good value inexpensive travel trailers.
 > Recommendations? Good value inexpensive travel trailers.
Cambria, California area
Posted: 09/18/22 11:41am Link  |  Quote  |  Print  |  Notify Moderator
Used trailers inspected closely can be a good deal.
* This post was edited 09/18/22 12:58pm by Lwiddis *
Thermoguy
Graham, WA
Posted: 09/18/22 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
valhalla360 wrote:
Quality doesn't vary significantly across the price ranges. The higher ranges are usually about image and bling...and fancy bling tends to mean more stuff to break.
- If you buy new, expect to have bugs to work out initially.
- If you buy used, someone might have worked the bugs out or might have let it rot (and that rot can happen quick with abuse). Without experience, good luck telling the difference.
- Then there is ongoing maintenance. Every time you travel it's like taking a house thru a combined hurricane and an hours long 7.0 earthquake simultaneously. If you don't keep up on maintenance, expect things to fail.
If you are expecting automotive type quality control, where you just drive it for 100-200k miles without issue, I suggest picking a different hobby.
PS: Go on youtube and search for RV repairs...put in the high end brands like airstream...you will still find plenty of expensive repairs.
This is a good answer to the OP's question IMO. I don't have a lot of experience only owning 1 RV in my life, but reading, it seems it's hard to have different quality when everyone is using the same parts. When I was shopping, weight seemed to equate to quality, the nicer something was put together, used thicker interior walls, nicer hardware, it was heavier. But, that's just my opinion. I also think Airstream has a reputation for higher quality, less issues, but that is not from experience. I have a friend with one, and he loves it. Not sure about your weight restrictions. Have you thought of something like a Sprinter class B series van? that would use a lot of the car like materials such as roof, siding, etc, but then have RV materials inside. Small but seems nice. People that have them like them.
* This post was edited 09/18/22 01:10pm by Thermoguy *
MitchF150
Puyallup, WA
Posted: 09/18/22 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
There is no direct answer to your question.. It's all opinions and luck of the draw and whatever it is you desire in an RV..
What I like in an RV is probably not what you like or want, or visa versa..
You can have two exact same rigs on a lot, you buy one, I buy the other for the same price. Take them out and maybe one ends up leaking or a cabinet door falls off, but the other one is fine... How do you quantify that result?
You can't..
If you want an answer, the 2019 Forest River Rockwood Mini Lite TT I have is the best built rig I've ever had... [emoticon] It's only my second TT in some 20 years. The first one was a 2003 Fleetwood Prowler Lynx and it also was a very good TT and traded it for the Rockwood and got a heck of a deal..
If you bought the same 2 rigs, you may or may not have the same results?
In the end, get off your computer, go out to an RV lot and look at them! [emoticon]
You'll know if it's a pile or if it's got potential and what you are looking for in floorplan, size and such. Price is usually only a concern if you are on a budget or on the verge of homelessness.. [emoticon]
So, take the "free" advice and opinions on the internet and go from there I guess.. You'll still have the same chance of getting a good one or a bad one either way IMO..
Good luck! Mitch
klutchdust
Orange, California
Posted: 09/18/22 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
I can answer using motorhomes as an example. BIL owns a Monaco, another friend leans towards Prevost, high end Prevost, the cost of a small house Prevost.
They all have issues. The more options the more issues. Slides don't slide, cabinets loose, wiring nightmares. One Prevost the marble floor had to be partially removed to repair a slide cylinder.
i purchase a 32ft. Wells Cargo gooseneck cargo trailer, ordered it with the roof to be one foot taller. i installed 12 ft. of living space myself. It was as nice as if the factory had done it at half the cost. I hauled my Jeep in it to the desert etc. That trailer was as rugged as heck and the frame and structure was strong because it started out as a cargo trailer.
Sold it for a class C Cambria and now back to a toy hauler. I have a 25ft. Work and Play by Forest River. It too started it's life as a cargo trailer and then the living quarters are installed. It is rugged but heavy. I really like it. The frame and structure is solid.
All RV's use basically the same appliances. Easy to repair if you have mechanical abilities. You tube is amazing to get pointers. i personally dislike aluminum sided trailers. I prefer the one piece smooth sides without slides.
As was mentioned, hit the rv lots, look around. You can walk into trailers and immediately say " I would not buy this". If you look up trailers and related issues I think you will find they kind of even out with complaints.
As a pickup owner....Ford, GM or Ram. Each has their good and bad.......
