RV.Net Open Roads Forum: Tech Issues: Electric tongue Jack blows fuses
 > Electric tongue Jack blows fuses
Whangler
Northern CA
Posted: 09/17/22 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
New trailer came with a Barker VIP 3500 tongue Jack. It blows the fuse (30A) when I reverse direction. If I stop and wait a moment before reversing direction, fuse doesn't blow. Other than this, the jack works fine. This is my 4th TT with an electric tongue jack but this never happened on the others. Any ideas?
SAR Tracker
Central Oregon
Posted: 09/17/22 10:11pm Link  |  Quote  |  Print  |  Notify Moderator
You have to allow the motor to stop before reversing. It's like going from drive to reverse in a car. Nothing good happens if you don't allow everything to stop.
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
ktmrfs
Portland, Oregon
Posted: 09/17/22 10:55pm Link  |  Quote  |  Print  |  Notify Moderator
yup. same thing on my atwood jack, my smaller barker ball screw and my barker 3500 ball screw and on my max air fan.
basic analysis of electric motor principles of operation will show a much larger than normal current draw with motor running in the reverse direction when voltage is applied.
2011 Keystone Outback 295RE
NamMedevac 70
Reno
My electric tongue jack failed me in very cold and wet freezing rain when wind chill was below freezing and my crank handle was missing so I later removed the jack and relied on only hand cranking with better results anyway with no more worries or hassle. Hand cranking was good for my health and increases already really good character and patience. Cheers to common sense.
Skibane
San Antonio, TX
Posted: 09/17/22 11:37pm Link  |  Quote  |  Print  |  Notify Moderator
If you get tired of replacing fuses, you could install a 30 amp self-resetting DC circuit breaker instead.
Whangler
Northern CA
Posted: 09/18/22 08:13am Link  |  Quote  |  Print  |  Notify Moderator
What y'all are saying makes sense.... But,this is my 4 tt with electric tongue jack over 20 years and this never happened. This isn't some new behavior of mine that suddenly appeared. 2 Atwood jacks and an ultra-fab 5500 prior to this Barker. If the other jacks had behaved this way, I wouldn't have this this **** habit. I guess this is a character builder, eh?
Goostoff
Wisconsin
Posted: 09/18/22 08:58am Link  |  Quote  |  Print  |  Notify Moderator
Dont think in all my years I ever saw a jack with a fuse. I just put an electric jack on my car trailer and the instruction had me wire directly to the battery. My landing gear on my 5th wheel has self resetting a circuit breaker in line but thats the most I ever saw
1993 Chevy C3500
2005 Cedar Creek 34RLTS
ktmrfs
Portland, Oregon
Posted: 09/18/22 09:30am Link  |  Quote  |  Print  |  Notify Moderator
I've had 3 different electric jacks over the years, all came with a 30A fuse wired into the pigtail.
ktmrfs
Portland, Oregon
Posted: 09/18/22 09:32am Link  |  Quote  |  Print  |  Notify Moderator
The atwood I had on another trailer behaved like the Barker. change direction quick before it completely stops= blown 30A slow blow fuse.
bgum
South Louisiana
Posted: 09/18/22 10:06am Link  |  Quote  |  Print  |  Notify Moderator
The fix is easy. Just don't do it. Electric tongue jacks are unreliable. I have a new jack in the garage that was replaced by a manual crank type. The Electric all are subject to moisture intrusion in the switches.
