RV.Net Open Roads Forum: Moving spots at RV park ? about weight distribution
 > Moving spots at RV park ? about weight distribution
OregonMan
Oregon
Posted: 09/19/22 09:38am Link  |  Quote  |  Print  |  Notify Moderator
Hi guys so I have to move to a different spot today at the RV park. My trailer is relatively light weighing less than 5,000 lbs. Should I attach the weight distribution bars when moving spots, or is it okay to just use the ball hitch? I was planning on staying hooked up overnight as well. Thanks for any tips.
ktmrfs
Portland, Oregon
Posted: 09/19/22 10:24am Link  |  Quote  |  Print  |  Notify Moderator
as long as your within the weight carrying capacity of of the reciever, (many recievers have a weight carrying limit that is less than weight distributing) not an issue IMHO. I move my trailer from the RV lot in our neighborhood to the driveway and back w/o hooking up the WD.
2011 Keystone Outback 295RE
Posted: 09/19/22 10:52am Link  |  Quote  |  Print  |  Notify Moderator
Wdh not needed.
But then again, I wouldn’t even own one for that light of a camper behind your newer F150.
mleekamp
Washington, IL
Agree with ktmrfs. If not on the highway, and just moving short distance at 5 or 10mph, no bars needed. But if staying hooked up overnite (you don't mention if leaving next day or ?) I'd just hook them up.
valhalla360
No paticular place.
Posted: 09/19/22 10:55am Link  |  Quote  |  Print  |  Notify Moderator
We've done it from time to time...
I'm assuming you are tooling around the park at 5mph, so most of the reason for a WDH goes away.
Even if it leaves you slightly over the carrying limit, I wouldn't worry too much. That's largely controlled by hitting a big bump at high speed...at 5mph, the dynamic forces will be nothing close to those at 60-70mph.
Do be careful to think things thru. It's really easy to mess something up when you aren't following your normal process.
Correction: I missed the part about staying hooked up...put the bars on. Nothing saved by not and one less thing to forget in the morning.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
JIMNLIN
Oklahoma
Posted: 09/19/22 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
For that small trailer moving a few campsite down there is no need for the bars or even to have a the WD system hitched up for that short move.
Southern California :(
Posted: 09/19/22 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
I think you'll be fine without the WDH.
Draggo
Rochester, NY
Posted: 09/20/22 11:00am Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't worry about it just to move around the park. I used to store my TT about a 1/2 mile from the campground and since it was an old country road where I could go slow I would just drop it on the ball and never had a problem. This was with a heavier TT (about 7K) and 1/2 ton pick-up (not the one in my signature).
Mike & Company
2021 GMC Sierra SLE (6.6L V-8, 3.73 rear gear)
2018 Coachmen Freedom Express 279RLDS
Reese W/D & HP DC
