RV.Net Open Roads Forum: Tech Issues: Automatic Transfer Switch problem
 > Automatic Transfer Switch problem
Alraz24
home
Posted: 09/19/22 11:12am Link  |  Quote  |  Print  |  Notify Moderator
My Ac will not run off generator. It runs fine off shore power. When trying to run off generator the AC will try to come on and then shut down to only fan working. Generator will still run, but produce no power and AC fan will run, but no compressor(just warm air)then later it will produce 120 volts again but, no ac compressor. Thought it might be automatic transfer switch so I wired a female plug end to the out put of the generator and plugged my shore power line in to it. AC and generator all runs fine. Do I need a new transfer switch?
Thanks
Mike
CA Traveler
The Western States
Posted: 09/19/22 11:42am Link  |  Quote  |  Print  |  Notify Moderator
Open the ATS and check for burnt contacts, wiring etc. To be really sure wire nut the gen wires to the CB panel wires at the ATS and check the A/C.
2014 Grand Cherokee Overland
Bob
Y-Guy
Tri-Cities, WA
Posted: 09/19/22 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
Which generator do you have? Just checking to see if you have you checked that both breakers on in the ON position no your generator?
2007 Winnebago Sightseer 35J
2011 Jeep Wrangler
arhayes
Posted: 09/19/22 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
The breakers was also my first thought, but since you bypassed the AT switch and it worked, that’s probably not it. I’m assuming your Genny puts out 44amps and you’re not exceeding capacity? Mine will only run 2 of my 3 AC’s. If you’re comfortable digging into the ATS, you can cut off power and look at the Genny side solenoids to make sure the contacts are clean. Barring that, it’ll need replacement. I had to replace mine 2 yrs ago (rig was 6 yrs old) got the same one installed in my rig off Amazon. Pretty straightforward replacement.
Alan and Kathleen
2015 Grand Design Momentum 380TH (RVD2)
2014 F350 6.7L Diesel DRW (Stormtrooper)
2012 Honda Goldwing NAVI/ABS (Land Speeder)
Bobbo
Wherever I park
Posted: 09/19/22 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
This statement is saying that the air conditioner has tripped the generator's breaker by drawing too much current. You have too much air conditioner and not enough generator. Adding an Easy Start to the air conditioner MAY help. Then again, it may not, depending on the size of the air conditioner and the size of the generator. My Honda EU2000i generator runs my 13,500 btu air conditioner with Easy Start installed near sea level just fine, but at altitude, it still fails.
Bobbo and Lin
Posted: 09/20/22 04:55am Link  |  Quote  |  Print  |  Notify Moderator
30 or 50 amp RV
On a 30 the generator often has TWO circuit breakers one 20 amp one 30 amp
The 20 is for the AC and nothing else.
Alraz24
home
Posted: 09/21/22 09:28am Link  |  Quote  |  Print  |  Notify Moderator
It is a 30 amp. Can't see where it has tripped any breakers. When the ac wont run on generator when going through the transfer switch and then I plug it into the plug I wired to the generator out put and did nothing else, such as reset any breakers, it would seem to eliminate any breaker problem.
