RV.Net Open Roads Forum: Tech Issues: Running portable generator off vehicle fuel tank.
 > Running portable generator off vehicle fuel tank.
jjrbus
FT Myers FL
Posted: 09/19/22 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
On another forum someone posted about running a Honda EU2200i off the original fuel line from the removed Onan. I have been using the mighty little Honda forever and never heard of tapping into the vehicle fuel supply. Does not seem right? Any input on this.
Southern California :(
Posted: 09/19/22 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
I wouldn’t consider this idea. Others might. I want my TV’s fuel supply not to have “stealth” drainage.
opnspaces
San Diego Ca
Posted: 09/19/22 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
I don't see why not. The Honda has a fuel pump so I imagine it would work just fine with a modified fuel cap like those for running extended tanks.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Bobbo
Wherever I park
Posted: 09/19/22 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
I just use an extended run fuel system. The 6 gallon tank lasts a couple of days at moderate amp draw.
Extended Run System
Bobbo and Lin
Skibane
San Antonio, TX
Posted: 09/19/22 10:36pm Link  |  Quote  |  Print  |  Notify Moderator
You'll need a low-pressure electric fuel pump (to replace the one on the Onan you yanked out of the RV), along with an adjustable fuel pressure regulator to reduce the fuel pump's 4-5 PSI output to just a small fraction of a PSI (which is what the pressure coming out of a gravity-fed fuel tank would normally be).
This prevents the generator engine from running rich or flooding out, due to excessive fuel pressure.
For safety's sake, the electric fuel pump will need to be connected so that it shuts off if the generator engine dies for any reason.
Many portable generators have a 12 volt DC "battery charger" output that can be used for this purpose - basically, the battery charger output powers the fuel pump whenever the engine is running.
You'll also need to add a "prime" bypass switch that allows the fuel pump to be manually turned on for a few seconds while starting the generator.
jjrbus
FT Myers FL
Posted: 09/20/22 04:49am Link  |  Quote  |  Print  |  Notify Moderator
I have used the external tank for years. My concern is the vehicle fuel system is pressurized, would it push fuel through the Honda? Just does not sound right.
Posted: 09/20/22 05:01am Link  |  Quote  |  Print  |  Notify Moderator
With most makes of generator you are correct.
With a HONDA. they put on on the generator at the factory.
As someone posted up thread the HONDA is designed to suck fuel from an external "Extended run" tank. they even showed a photo of the set up.
Honda sells the tank and the "Modified" gas cap needed to use it.
The procedure is fill the "on board" tank. and the external. replace the original gas cap with the "extended run" cap and it sucks the extended tank dry. You then swap caps back (Running off the on board) While you run to ye old fuel pump to refill the extended tank.. Can run a long. long, long time that way.
TO THE ORIGINAL POSTER
Be sure to put a shut off valve line (two in fact) in the line from the RV's primary tank. One manual and one "Quick Disconnect" type to insure the line does not express fuel when the tank is filled.
Skibane
San Antonio, TX
Posted: 09/20/22 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
Drawing fuel from a tank sitting right next to the generator isn't the same as drawing it through several dozen feet of fuel line to a tank mounted somewhere else on the RV.
Depending on the particular RV, there may also be some additional restriction from a fuel filter.
Posted: 09/20/22 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
The vehicle fuel system is not pressurized... There is a pump (External to the ONAN generators but very close to it)( specific to that line. the line pre-that pump is not pressurized might be slight vacuum in fact.
A Separate line to the main engine IS pressurized. But that is for the Motor home's motor.
valhalla360
No paticular place.
Posted: 09/20/22 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
Modern vehicle fuel systems are sealed for emissions reasons and get fussy if that seal is lost. How exactly would you be tapping into the tank?
The outboard tank with honda transfer cap really makes far more sense.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
