RV.Net Open Roads Forum: Tech Issues: what size inverter.
 > what size inverter.
ktmrfs
Portland, Oregon
Posted: 09/20/22 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
wa8yxm wrote:
As they said 300 watts for Entainerment/computer only
1500 is the absolute minimum for a Microwave I'd go with 2,000
Panasonic true inverter microwaves run just fine on a 1000W inverter if you set power to 50% max. Done that for 8 years now. yes, things take a bit longer (maybe 50%) to heat, but that's it. 50% is drawing about 750-800VA, you can actually go to 70% or so if you have a big enough battery bank and are reasonably charged. 50% works on a set of 4GC2's discharged to around 50-60%.
Now a conventional microwave, yes 1500W minimum.
2011 Keystone Outback 295RE
StirCrazy
Kamloops, BC, Canada
Posted: 09/21/22 06:41am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
1800 watts for single hi draw items such as an induction hob.
300 watts for tv, computers, and cell phone charging.
you running two inverters PT? I just want one but I want to size it so I cannot draw full current through the BMS on the new battery. its for the camper not the 5th wheel, I have a 2000 watt inverter in the 5th but a 2000 watt inverter can pull 166 amps and I am only using a 150 amp BMS on this one. when I do another then I can handle twice that with two batteries.
right now I have no need for AC in the camper aside from charging phones which I can do with DC, but I thought it might be nice to use the electric toaster (700 watts) once and a while and if we decide to keep this old camper instead of upgrading to a newer one then maybe add some other stuff. if I can find a decient 1500 watt pws inverter that will draw 125 amps max for a reasonable price here in canada that might be what I am looking for.
* This post was edited 09/22/22 07:54am by StirCrazy *
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
pianotuna
Regina, SK, Canada
Posted: 09/21/22 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
my microwave draws 1565 watts. 1500 is not going to cut it for me.
Regards, Don
dodge guy
Bartlett IL
Posted: 09/21/22 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
Just got a 3000W inverter for my MH. It’s only to run outlets and maybe the microwave on the road. I only have 2 batteries, but will never pull the full wattage. It when it comes time for batteries I’m thinking 3 100Ah LifePo batteries.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
StirCrazy
Posted: 09/22/22 07:53am Link  |  Quote  |  Print  |  Notify Moderator
wow, is that a comercial restuarant model? I havent seen one rated over 1100 and that being one of the biggest ones, most I see are 900 to 1000.
StirCrazy
Posted: 09/22/22 08:00am Link  |  Quote  |  Print  |  Notify Moderator
ya I am building my own LiFePO4 so using 320AH cells which is great for the amount of capacity available from one battery , but to get a good quality BMS that will handle 3000 watts gets a little pricy. Im already going higher than my last battery by using a 150amp bms. my original plan was to use a 120 and save 30 bucks but I decided when I build a second one they will handle a 3000 watt inverter no problem so for the 5th wheel they will run cool on a 2000 watt inverter.
I was also looking at the smaller inverter waist less power while they are on but not being used so there is a efficicency thing I am looking at also.
ktmrfs
Portland, Oregon
Posted: 09/22/22 09:00am Link  |  Quote  |  Print  |  Notify Moderator
Microwaves have two spec's on "watts". the advertized one, which is usually the OUTPUT power, then on the back plate the actual power draw from the line. The first is commonly in the 1000W range, the second is usually in the 1300-1500 watt range. At least in the U.S. if current draw exceeds around 12A they need to be equipped with a 20A plug rather than the common 15A plug. That pretty much limits them to 1500 or so watts actual power draw.
Then there is the power draw and VA. Since they are not a resistive device and usually no power factor correction, the current draw (which inveters care about) will usually be higher than derived from assuming a resistive load.
StirCrazy
Posted: 09/23/22 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
yes, I thought he was talking about the output when I saw that. my 1100 watt one only draws 1200 watts which also had me wondering.
pianotuna
Regina, SK, Canada
Posted: 09/23/22 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Mine was measured with a Kill-a-Watt meter--which has been checked against a seriously expensive meter.
It is a Dometic.
time2roll
Posted: 09/23/22 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
It is a Dometic.
1565 watts but did you measure power factor?
I think the PF killed my Prosine 1800 prematurely.
675w Solar pictures back up
