RV.Net Open Roads Forum: Truck Campers: Battery Charging on Truck Camper
 > Battery Charging on Truck Camper
bkenc
columbus mt
Posted: 09/19/22 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
Hi. Just purchased a used 2009 Sunlite 8'. On a 2017 Ford F350. I would like to charge the battery (has a Group 24 RV battery) while driving. There is no manual. The TC has a 6 pin round male connector up front. Can I purchase a connector that uses my 7 blade trailer hook up that would connect to the 6 pin round to charge the battery? Or, do I need to run a direct line from the battery? Any help would be appreciated.
pianotuna
Regina, SK, Canada
Posted: 09/19/22 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
For better results, invest in a dc to DC charger.
Regards, Don
mkirsch
Rochester, NY
Posted: 09/20/22 06:15am Link  |  Quote  |  Print  |  Notify Moderator
Can you purchase? Probably not. Most likely the camper is wired in a non-standard way compared to a trailer.
That was what happened with my Palomino. It has a standard 7-pin plug in the front, but it's wired different from a trailer.
You'll need to figure out which pin does what, and if there is a 12V pin. Draw a picture of the connector on a piece of paper with plenty of room around it to make notes. With a battery in the camper, use a piece of wire to briefly jump any two pins together. Just a quick tap. If you get a spark, you found 12V and ground. To figure out which one, switch to a different pin on one end of the jumper. If nothing happens, you now know which of the first two pins are 12V and ground. If a light comes on, again, you know which is which. Take notes. Now start poking between the 12V and the other pins on the connector and see which lights come on as you do that. Take notes.
Now you can get a 7-pin, a 6-pin and enough cable to reach, and make up your own custom connector.
In your case it will be easy to know which end plugs into the truck and which plugs into the camper. In my case I put it in backwards once and nothing worked right. I had to raise the camper back up to get at the plug in my bed to swap ends on the cord. Then I wrapped tape on the truck end. T is for tape, and for truck.
mellow
Salisbury, MD
Posted: 09/20/22 07:45am Link  |  Quote  |  Print  |  Notify Moderator
You get something like this: https://www.adventurerv.net/lance-6wire-........4.html?osCsid=07n2jvaf0hp8hrbejila92vep7 and then put a 7pin adapter on the end to plug into your existing 7pin plug, then your 6pin plug goes into the other end.
2002 F-350 7.3 Lariat 4x4 DRW ZF6
2008 Lance 1191 - 220w of solar - Bring on the sun!
bkenc
columbus mt
Posted: 09/20/22 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Thanks all! Now I know how to start.
Cambria, California area
Posted: 09/20/22 10:23am Link  |  Quote  |  Print  |  Notify Moderator
Consider solar for primary recharging. No need to be driving.
Posted: 09/20/22 10:53am Link  |  Quote  |  Print  |  Notify Moderator
Old camper with a mfg specific or obsolete plug, cut the sucker off and install a matching 7 pin. Then everything is the same, no mix n match/adapters or old plugs. Easy to wire the 12V + pin for charging.
Or do the same but also install a dedicated charging circuit with or without a DC DC charger depending on how serious you are about charging off the truck.
Good luck!
2017 Heartland Torque T29
#1Flyboy
California
Posted: 09/20/22 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
Put a solar panel on the TC roof & your batteries will be charged on the road, at your camp spot AND when it’s parked at home…. My batteries are fully charged EVERY day by sunlight…….
mkirsch
Rochester, NY
Posted: 09/21/22 10:02am Link  |  Quote  |  Print  |  Notify Moderator
Solar is quite an investment, especially if you install enough solar to handle charging from heavy battery use. That's assuming you have enough roof real estate.
The sun doesn't always shine either.
StirCrazy
Kamloops, BC, Canada
Posted: 09/22/22 07:51am Link  |  Quote  |  Print  |  Notify Moderator
I don't know why people think it is such an investment, and what i heavy battery use? as long as your not trying to run an AC then it is far from an investment, well, maybe if you buy it from a rv dealership and have them install it for about 10X the price if you source and install yourself. for me it was haf the price to put my solar on than to buy a 1000watt honda generator.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
