RV.Net Open Roads Forum: 1997 Chev P30 Dolphin motorhome fuel pump relay switch
 > 1997 Chev P30 Dolphin motorhome fuel pump relay switch
larryPonich
Vegreville
Posted: 09/20/22 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
I need to find out which colored wire goes to which terminal on the
5 pin relay as the wires were pulled out.
MountainAir05
New Mexico
Posted: 09/21/22 09:46am Link  |  Quote  |  Print  |  Notify Moderator
This is for relay 15528707 go down to reply 18 and see if is the one you have.
https://www.classicwinnebagos.com/forum/index.php?topic=8795.0
Chum lee
Albuquerque, NM
Posted: 09/21/22 10:20am Link  |  Quote  |  Print  |  Notify Moderator
The relay should have a schematic printed somewhere on it. (shows which wires do what) There should be two larger size wires (current from main bus to fuel pump) and three smaller control/signal wires. If you can find a wiring diagram (factory service manual) it will tell you which color goes to which terminal.
Chum lee
