traildog
Pendleton, IN USA
Hello!
On the way to our campsite, we used the pump several times.
Got all set up and turned on the pump and it runs but won’t pump.
All fittingsare tight, tank is full but no water is pumping.
Could it have lost its prime?
Thanks
TD
2021 Coachmen Freedom Express Ultra Lite 259FKDS.
2021 Ford F-150 3.5 ECO BOOST 4:30
schlep1967
Harrisburg, PA
Pump is self priming. How did you verify the tank is full?
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
pianotuna
Regina, SK, Canada
How old? What make and model of pump?
Regards, Don
midnightsadie
ohio
check fuse. if your reading the empty/full gauge? they are not very good at telling the true water left in the tank.
traildog
Pendleton, IN USA
schlep1967 wrote: Pump is self priming. How did you verify the tank is full?
I pulled the drain, let some of the water out and then refilled it. It’s full.
traildog
Pendleton, IN USA
pianotuna wrote: How old? What make and model of pump?
Camper is 2 years old. I looked at the pump but I’ll have to get the make and model later today.
traildog
Pendleton, IN USA
midnightsadie wrote: check fuse. if your reading the empty/full gauge? they are not very good at telling the true water left in the tank.
Pump runs but doesn’t pump.
wolfe10
Open a faucet. If there is an air pocket, that will aid in bleeding the air out.
If that doesn't work, open the kitchen sink faucet, and with the pump turned on, suck on the faucet. That will, as above, help bleed the air past the pump.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
schlep1967
Harrisburg, PA
Check your settings in the wet bay. You may be feeding water from the tank to the tank.
MFL
Midwest
wolfe10 wrote: Open a faucet. If there is an air pocket, that will aid in bleeding the air out.
I agree with the first part, but that sucking the faucet, should not be necessary, unless a roach is trapped in the line.
Also don't be afraid to let the pump run dry for a bit, waiting for it to prime. It will not harm it.
Jerry
