RV.Net Open Roads Forum: Tech Issues: Why did my water pump stop pumping?
 > Why did my water pump stop pumping?
traildog
Pendleton, IN USA
Posted: 09/22/22 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
StarkNaked wrote:
Is there a valve in the wrong position (or not quite all the way in the correct position)?
Drain valve? Winterizing valve? Bypass valve? Water heater valves?
Nope. We stopped and used the pump on the way to our campsite.
2021 Coachmen Freedom Express Ultra Lite 259FKDS.
2021 Ford F-150 3.5 ECO BOOST 4:30
pasusan
Northernmost PA
Posted: 09/22/22 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
opnspaces wrote:
Go a step beyond just turning on the faucet. Unscrew the aerator out of the end of the faucet. Turn the faucet on and and let the pump run.
^ Definitely try this! We just had this happen a couple weeks ago and I thought the pump was broken - it was the aerator that was somehow broken (it was a swivel one). Water flowed nicely when I unscrewed it.
"I'm out here to enjoy nature -- don't talk to me about the environment!" ~Denny Crane
Susan & Ben
2004 Roadtrek 170 for quick getaways
84 Bronco & 90 Award Classic 23 joined with a Hensley Cub for longer trips
Trip Pics
1320Fastback
Vista, Ca
Posted: 09/22/22 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have a water filter? Possible under the sink? I just changed mine this evening while filling the fresh tank up and had a heck of a time getting all the air bled even though I prefilled the filter and bled the water heater.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
TurnThePage
North ID
Posted: 09/23/22 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Recently we had the same thing happen. I looked everywhere. Finally, digging around under the sink (where the pump is) I noticed the wife had stuffed a cleanser bottle into a corner, which happened to be where the water line came from the tank. The line was pinched just a little bit. When I removed that bottle, the water started flowing.
2015 Ram 1500
2004 Pioneer 18T6
MSchu
Posted: 09/23/22 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
On my shurflo 4008 pump the problem was a stuck pressure valve under the diaphragm. There was a You tube video on how to fix it by a channel by the name "Why Wait"
traildog
Pendleton, IN USA
Posted: 09/24/22 04:44am Link  |  Quote  |  Print  |  Notify Moderator
Yes, someone posted that link and I believe that’s the only thing that could have happened.
It’s going to be one heck of a challenge to get the pump out but it’s got to be done.
I’ll update my findings when it’s working again.
Thanks for all the replies!
TD
traildog
Pendleton, IN USA
Posted: 09/24/22 04:48am Link  |  Quote  |  Print  |  Notify Moderator
Pump
Pump location
* This post was edited 09/24/22 05:00am by traildog *
traildog
Pendleton, IN USA
Posted: 09/25/22 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
So, I filled the FW tank when I got home and turned on the pump and let it run with the sink faucet on.
It took a couple of minutes but sure enough, it starting spitting water and air. I turned every sink, shower and activated the flush valve until all stopped sputtering.
Strange thing was, the pump never completely shut off. It slowed to a VERY slow “idle” but kept turning. Then, it stopped completely and now won’t come back on. I think I toasted it but haven’t checked the fuse yet.
traildog
Pendleton, IN USA
Posted: 09/25/22 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
I pleased to report that my pump is now cycling normally.
WHAT THE HECK???
Veebyes
Posted: 10/02/22 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Possibly an air leak on the low pressure side of the pump.
Loosen & retighten fittings at filter, if present, & tank side of pump. Check filter while at it.
2007 Alpenlite 34RLR
