RV.Net Open Roads Forum: Class A Motorhomes: Norcold on Inverter
 > Norcold on Inverter
BigDaddy1951
Leesburg, FL
Posted: 09/22/22 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
I am concerned about running my Norcold 1200 refer on the onboard inverter. 2007 Winnebago Voyage. I believe the inverter is 600 watts and the refer draws 2.9 amps on 110, or about 330 watts. This way I could run the refer driving with the gas off. Any ideas or suggestions would be appreciated.
* This post was edited 09/22/22 07:57pm by BigDaddy1951 *
MountainAir05
New Mexico
Posted: 09/22/22 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
what is your concern. You are almost double what you need so all you can do is try it.
BigDaddy1951
Leesburg, FL
Posted: 09/22/22 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
I just wondered if anyone had done this. Don’t want to mess up my old rig!!
jorbill2or
Full time
Posted: 09/22/22 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
Well , I know a few folks that don’t but I know many more that just leave the gas on. Most gas refrigerators are plugged into a non inverted outlet. ( except for the ice maker ) . Most that run without propane on just leave the fridge off. Be sure to change it to the inverted circuit if there is one , if that’s what you decide to do.
Bill
BigDaddy1951
Leesburg, FL
Posted: 09/22/22 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, I have used it and left the propane on many times. I was taking the NRVTA home study course and they recommended leaving the propane off for safety. That was right after the part on converters and inverters. It got me thinking, which may or may not be a good thing, LOL. Thanks for the response!
pianotuna
Regina, SK, Canada
Posted: 09/22/22 11:20pm Link  |  Quote  |  Print  |  Notify Moderator
I've done it many times.
The inverter may draw about 30 amps@ 12 volts.
Regards, Don
craig7h
Branson MO area
Posted: 09/23/22 03:17am Link  |  Quote  |  Print  |  Notify Moderator
Why not run your generator? This way you will have the frig on plus you can run the ac to keep coach cool.
Itasca Meridian SE 36g
Road Master Tow Dolly
erniee
Weatherford, Texas 76086
Posted: 09/23/22 05:36am Link  |  Quote  |  Print  |  Notify Moderator
I’d be more concerned about that POS catching fire
Ernie Ekberg, Prevost Liberty XL Classic
Cambria, California area
Posted: 09/23/22 08:44am Link  |  Quote  |  Print  |  Notify Moderator
Why not just run the fridge on propane? As you have apparently been doing without issue.
wolfe10
Posted: 09/23/22 09:10am Link  |  Quote  |  Print  |  Notify Moderator
YUP.
I sure would not work my engine/alternator harder to provide electricity vs just leaving it on propane (as designed).
Is propane operation safe-- yes. Certainly more risk of vehicle accident than fire while driving due to propane use in refrigerator. But, YOU weigh the risks for yourself.
Yes, the refrigerator operating on propane needs to be turned off when refueling and tunnels where its use is restricted.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
