RV.Net Open Roads Forum: Tech Issues: Fridge Fan Swich Failed
 > Fridge Fan Swich Failed
Posted: 09/23/22 09:31am Link  |  Quote  |  Print  |  Notify Moderator
My 130°F thermo switch that controls the fans on the outside of my absorption fridge failed. I temporarily wired a mechanical switch in its place until I can get a replacement thermo switch.
Any problem leaving the fans on in 90° weather while traveling? Can this cool the rear fins off too much causing an issue?
Thanks
Fave
2013 KZ Durango 2857
dougrainer
Carrolton, Texas
Posted: 09/23/22 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Is the refer in a slide room? IF SO, running the fan 24/7 will yield the best possible performance of the refer. But, NO, to your question. There is no possible harm by running the fan 24/7. Doug
2112
Posted: 09/23/22 10:27am Link  |  Quote  |  Print  |  Notify Moderator
It is in a slide. I'll just leave them running.
Thanks
pianotuna
Regina, SK, Canada
Posted: 09/23/22 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
2112,
I've had zero problems with the computer fans I added. They are thermostatically controlled.
Regards, Don
2112
Posted: 09/23/22 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Don
The camper came with 2 what look to be about 80mm fans blowing across the fins on the upper portion in the rear. Very difficult to get to the fans. I've been having issues with the corroded spade lugs on the OEM thermally controlled switch that controls them.
Right now I have the Texas sun beating down on the fridge side of the camper, fans been running since this morning and it's 48° in the fridge.
It'll be down to 32° in there in the morning.
Unfortunately there are no spaces available here that face the other way
pianotuna
Regina, SK, Canada
Posted: 09/23/22 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
2112,
Any chance of using a tarp to create some shade?
2112
Posted: 09/23/22 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
I have some Reflctix I might try covering the outside area between the vent panels with. We are just here 1 weekend a month visiting here mom and hopefully fall will get here soon.
But there's always next summer
