RV.Net Open Roads Forum: Class A Motorhomes: Seat switch
Tom/Barb
Oak Harbor, Wa
Posted: 09/23/22 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
We have a seat that is out of production, it is a Flexseat. (vintage 2000) I need a toggle switch that controls the seat recline switch. It is a two position -- up or down it is not the 6 position that controls the lower portion of the seat..
They are no longer made.
Is there a work around or a different that will work..?
MountainAir05
New Mexico
Posted: 09/23/22 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
Tom,
try this place. I had one go out and had to upgrade to the newer switch.
Switches
try this one also
* This post was edited 09/24/22 08:55am by MountainAir05 *
Tom/Barb
Oak Harbor, Wa
Posted: 09/23/22 10:43pm Link  |  Quote  |  Print  |  Notify Moderator
MountainAir05 wrote:
Tom,
Switches
That isa the 6 way switch.. and the one is just the 2 way switch..
Tried them already
Y-Guy
Tri-Cities, WA
Posted: 09/24/22 12:01am Link  |  Quote  |  Print  |  Notify Moderator
Are there any model numbers on the switch? That might help to locate some others that have swapped with a newer part.
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
midnightsadie
ohio
Posted: 09/24/22 08:24am Link  |  Quote  |  Print  |  Notify Moderator
try a body shop they run into this kind of problem. or numbers on the switch .
Tom/Barb
Oak Harbor, Wa
Posted: 09/24/22 08:51am Link  |  Quote  |  Print  |  Notify Moderator
There are no numbers on the switch.. Zip ,, nada
That's part of the problem, no data to research.
LouLawrence
Traveling the US fulltime since 2000.
Posted: 09/25/22 07:56am Link  |  Quote  |  Print  |  Notify Moderator
See if a standard 2-way momentary switch will work. Should be available at any auto store. If that works you can either modify the seat opening or use that information to locate a similar switch that be a better fit on the internet.
