RV.Net Open Roads Forum: Fifth-Wheels: tire time
 > tire time
StirCrazy
Kamloops, BC, Canada
Posted: 09/24/22 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
ok so I am wondering what tires people are buying and having deicent luck with. had my second blow out in 39 years so time to look at tires.
I was going to go with the sailune but I don't want to have to buy new rims right now so it will be a standard under 100psi tire.
thanks
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
fj12ryder
Platte City, MO
Posted: 09/24/22 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
I happen to think that it isn't necessary to run max sidewall pressure for a tire. IMO you can vary your pressure to reflect the amount of weight on that tire. I ran "G" rated Sailun 16" tires at 95 psi for years, and they still looked good when I sold the trailer, and they were over 6 years old. I was running a triple axle toyhauler with about 2,500 lbs. on each tire, I weighed them so I know. I didn't need to the full 110 psi, and the resultant rough ride. It worked great for me.
Howard and Peggy
"Don't Panic"
JIMNLIN
Oklahoma
Posted: 09/24/22 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
Depends on what your trailers OEM axle ratings are.
For 5.2k-6k axle I use a good all season tread 16" LT235/85-16 E at 3042 lbs per tire. Michelin XPS Ribs and Bridgestone R238 are a commercial grade all steel ply carcass tire and are tops for those size axles
For My triaxle GN stock trailer with 7k axles I use Sailun S637 ST235/80-16 load G tire at max sidewall. In a heavy tire like a load G I personally wouldn't use any pressure less than 90 psi. Those are a very heavy stiff commercial grade tire and like all commercial grade tires they can run hot with lower pressures.
What ever tire that lasted 39 years I would stick with that brand...[emoticon]
time2roll
Posted: 09/24/22 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
You only buy tires after a blow out?
How about post the tire size and the trailer GVWR?
675w Solar pictures back up
corvettekent
Marysville, WA
Posted: 09/24/22 10:39pm Link  |  Quote  |  Print  |  Notify Moderator
Buy a LT (truck) tire instead of a ST (trailer} tire.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Turnover Ball, Companion Hitch.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
ETCrockett
Greenwood, IN
Posted: 09/24/22 10:41pm Link  |  Quote  |  Print  |  Notify Moderator
After my last blowout, I upgraded the China bomb tires from the factory with Tires Hercules LT 235/85R16 H-901 DOT LYC B2RLHE LOAD RANGE G tires. We bought them in TN at the Farmer’s CO-OP in Sevierville. The sidewall is 110 PSI cold but I follow the PSI recommended for the FW which is 85 PSI cold. I have been very pleased with these tires.
Eric & Andrea
2016 Jayco Pinnacle 38FLSA
2009 Ford F450 DRW
Southern California :(
Posted: 09/25/22 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Tires not made in China are immune to road hazards? Age? Under inflation? Over loading? Sun damage?
phillyg
SWFL
Posted: 09/25/22 08:41am Link  |  Quote  |  Print  |  Notify Moderator
Based on your specs, an E or F-rated tire will do, so GY Endurance will work. If you want to upgrade to a G like Sailun or Hercules, and adjust psi downwards per their load range chart, you should be able to stay below your wheel rating.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
rhagfo
Portland, OR
Posted: 09/25/22 09:05am Link  |  Quote  |  Print  |  Notify Moderator
Our 12,360# GVWR 5er came stock with LT 235/85-16 tires we used the same as replacements. Yep, only 3,042# capacity each, but a better built and tested tire.
joebedford
Heading south for 1st time in 3 years
Posted: 09/25/22 09:45am Link  |  Quote  |  Print  |  Notify Moderator
I have Sailun 637s and run them at 80psi. That's plenty to support the weight of my tri-axle toy hauler.
 > tire time
