RV.Net Open Roads Forum: Travel Trailers: Do Some Travel Trailers Have Levelling Jacks?
 > Do Some Travel Trailers Have Levelling Jacks?
Gdetrailer
PA
Posted: 09/25/22 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
DallasSteve wrote:
Gdetrailer
Thanks for those tips. Maybe that's the better solution. Are the stabilizers/tongue lift usually manual? Can I use something like an electric screwdriver?
You can buy aftermarket electric tongue jacks and replace the manual tongue jack if the trailer was not equipped with an electric jack.
For bolted/welded on stabilizers you can often adapt a battery powered drill to run them up and down to speed up setup and tear down.
JRscooby
Indepmo
Posted: 09/25/22 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
Gdetrailer wrote:
How hard is it to toss a board under the trailer wheels and pull onto the board?
Answer, pretty easy.
How hard to toss boards under two or more wheels of a motor home?
Answer, not as easy as a trailer.
MH, you need to check 2 levels. 1 side to, the other front/rear. Then add what need to lift for the lowest corner. Then place the stacks so 3 wheels top at same time.
They do make levels with markings in 1 inch increments that takes most of the guess work out of leveling a trailer.
I use plastic blocks, and have my bubbles marked so each mark is another layer in the stack
When you get to your site, check the side to side level before unhitching, place your wood or plastic leveling blocks in front or behind the trailer wheels then pull on to the blocks. Now you have side to side done.
This is where many people have problems. Put board in front of left tire, when the right drops in a hole as you pull forward, too much board. Best idea is stack your boards centered on axle, move the trailer until can slide stack in line with wheel, put trailer back where it was, just higher.
I-Can-Am-Can-You
Licking County, OH
Posted: 09/25/22 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
Quadra makes systems for leveling just about anything.
Jack_Diane_Freedom
Burlington Ontario Canada
Posted: 09/25/22 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
I have a friend with a large TT with an auto levelling system and it works quite well. No problems after 3 years of use.
MitchF150
Puyallup, WA
Posted: 09/25/22 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
I think those self leveling jacks are placed a lot closer to the axles than at the very ends of the rig like the stabilizer jacks are placed..
I got the "strong arm" stabilizer jack extensions and those made a huge difference in the bounce/wobble of the rig once leveled..
I'll use boards under the tires to bring the rig close if it's off more than a full bubble of level just sitting there. More if necessary.. But, I crank them enough to get some weight on them to 'stabilize' the rig, then crank on the strong arm bars and it's pretty much rock solid at that point.
I know that's not your question, but I also jack up my trailer with a bottle jack to check the brakes and pack the bearings and I put jack stands on either side of the frame as close to the axles as I can and it's actually very solid!
I'd do that in the camp ground, but too much trouble and effort when my strong arms do a good enough job for "camping".. [emoticon]
Mitch
penguin149
Bowling Green, KY USA
Posted: 09/25/22 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
Pbutler97 wrote:
If you know what you're looking at, and crawl under most travel trailers that were built in the last 10 years or so and are on a Lippert frame, you might have second thoughts before you jack it up to change a tire let alone jacking the entire thing up off the ground to level it.
My thoughts as well! TT frames seem to be the thinnest possible to reduce weight and allow for more vehicles to be used as TV's. Leveling jacks would test frame strength and probably not turn out well! Same reason adding a lot of weight to the rear bumper scares me.
2021 Nissan Titan Pro-4X 5.6L V8 4WD - 2019 Keystone Bullet 243BHS
APT
SE Michigan
Posted: 09/26/22 08:52am Link  |  Quote  |  Print  |  Notify Moderator
There are systems available on some TT brands from the factory. I personally would not use that feature as a filter for which TT I buy. Every TT comes with a tongue jack (manual crank or electric power) which covers front to back leveling. Side to side as mentioned already is done with something under the low side tires (boards, plastic lego blocks, etc.). For me, I think the time savings of having a fully automatic system is about 5 minutes per arrival/departure. Cost for an electric jack is ~150 and another $50 for lego blocks.
2017 Subaru Outback 3.6R
2020 Chevrolet Bolt
ralph day
Ontario Canada
Posted: 09/26/22 09:10am Link  |  Quote  |  Print  |  Notify Moderator
I have the little stick on levels on my 19' coach. Just be sure you're looking at the correct one when levelling. We just got back from a trip, had the Anderson levelers under the tires in the usual driveway spot, but couldn't get the bubble in the middle! We were looking at the end to end level (on the trailer side) instead of the one on the trailer front for side to side level. Tired maybe?
Steve, go look at some travel trailers. That will answer most of your questions with visual cues.
p38fln
Superior, WI
Posted: 10/07/22 10:42am Link  |  Quote  |  Print  |  Notify Moderator
We have a friend with a 1984 Coachmen 32 foot travel trailer. It's virtually identical to our 1991 Citation 32 foot travel trailer. The Coachmen was obviously a higher class unit when new, his has leveling jacks at all 4 corners along with a built in analog clock and water tank sensors, while the Citation...has absolutely nothing. I level the Citation by putting jack stands under the frame between the rear axle and last crossmember before the bumper, lowering the nose jack, raising the jack stands, then raise the nose jack back up. I'm not trying to get the wheels off the ground just make the bathtub drain properly and keep the thing from bouncing everywhere when someone walks through the bedroom.
We had a 1991 Starcraft Starburst popup trailer before the Citation and its built in stabilizers could only be used to 'level' the trailer by messing with the nose jack as well. In that Starburst's case, if you didn't put some tension on the stabilizer jacks the door wouldn't stay shut and the single axle trailer would get extremely bouncy if someone got in one of the bunks without getting the jacks SOLIDLY on the ground.
FYI - He said only one leveling jack still works and he uses a bottle jack and a bunch of wood to level it.
