RV.Net Open Roads Forum: Leaky roof, any ideas where it’s coming from ?
 > Leaky roof, any ideas where it’s coming from ?
tourusa
Ft Lauderdale
Posted: 09/25/22 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
Hi fellow Rvers
I’m continuing my quest for a class A and have found one but has a small leak , any ideas where the leak is coming from, the roof has been redone and it’s on the side where the slide is but above see pictures. Any tips to fix thanks
midnightsadie
ohio
Posted: 09/25/22 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
the hole roof could be rotten you really don,t no. you could have a pressure test done.
MitchF150
Puyallup, WA
Posted: 09/25/22 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
Likely the drip rail on that side of the rig. By the time you see it on the inside, it's probably been leaking for awhile to have soaked thru..
So, roof line and probably forward and back from where you see it in the pic..
You could try to "seal" the outside, but damage is probably already done..
Without seeing it, no way to tell for sure, but that's my initial gut feeling by just the pics.
Good luck! Mitch
Southern California :(
Posted: 09/25/22 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
An RV with known leak and unknown damage is not an RV I’d consider buying.
tourusa
Ft Lauderdale
Posted: 09/25/22 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks all the roof has just been redone and seller is saying no soft spots
bgum
South Louisiana
Posted: 09/25/22 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
Avoid like the plague. Will cost over $3000 to repair.
johnhicks
Wandering below the Gnat Line
Posted: 09/25/22 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
Gasket under a/c
-jbh-
tourusa
Ft Lauderdale
Posted: 09/25/22 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks all, @john how hard to replace, have you seen this before ?
MitchF150
Puyallup, WA
Posted: 09/25/22 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
Ahh... Yes, the AC leaking could do that too.. I missed that.. Good catch johnhicks!
Still.. Depending on how long it's been leaking, could be more damage that just has not shown itself yet?
It would be a good idea to pull the AC unit and inspect further from there...
Seal is just a gasket and you'd have to remove the unit to do that anyway.
Not hard, per se... But a couple person job I'd say.
Mitch
dodge guy
Bartlett IL
Posted: 09/25/22 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
If they just put a roof on it and you are seeing this, avoid it. It’s one thing to have it happen after you buy it, it’s another to purchase knowing it’s currently their.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
