RV.Net Open Roads Forum: Class A Motorhomes: adjusting slide out
 > adjusting slide out
dalefuji
Milton, Pa.
Posted: 09/25/22 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
I have 1998 Holiday Rambler Endeavor. The slide out needs adjusted.
I have RV leveled with jacks down. It is level left and right. When I put level on top of slide out at front, it is level. When I put level on top of slide out at rear, the level shows 1/8 of a bubble towards inside which is good. If rain blows under topper (cover) it will run away from slide out seal. If rain blows in under topper at front, it can run towards seal. There are two rollers under slide out inside. Is there adjustment on front roller under couch to make front of slide out slant out??? There is no debris on top to prevent slide from going out all the way.
