RV.Net Open Roads Forum: Class A Motorhomes: Low power?
 > Low power?
David0725
Posted: 09/26/22 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2003 DS 50amp It is currently plugged in to my 30amp server at my house. Im using 2×25ft 50amp cords.At first it's show 111volt turn on the A/c it drops 108 or so. What could be causing this? But with I run the generator it's fine 115 120. Thank you in advance.
1994 Holiday Rambler Imperial DP
1999 Honda Accord V6 Toad
Bruce Brown
Northern NY
Posted: 09/26/22 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
Voltage drop through the extension cords.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
rk911
DuPage County
Posted: 09/26/22 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
if it drops below 108v i'd disconnect before damage is done. but what's a 'DS' and what is a 30-amp "server"? do you mean a 30-amp outlet at a campsite? but the first response is likely correct...voltage drop through the cords. did you measure the voltage at the post?
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
Bruce Brown
Northern NY
Posted: 09/27/22 04:30am Link  |  Quote  |  Print  |  Notify Moderator
^^^ It says he's plugged into a 30 amp at his house.
wildtoad
Blythewood, SC
Posted: 09/27/22 05:03am Link  |  Quote  |  Print  |  Notify Moderator
I suspect DS is Dutch Star (Newmar). “Server” may be “Service”. Is it possible to move closer? You might want to consider upgrading the service to 50 amps.
As above the length of cords will reduce the voltage. Generator is properly sized for the MH providing 50 amps, and is really really close by.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
larry cad
ohio
Posted: 09/27/22 06:50am Link  |  Quote  |  Print  |  Notify Moderator
For a nominal voltage of 120V, ANSI allows a range of 104.4 - 127.2 as acceptable. However, NEMA requires electrical equipment be able to operate within a range of 103.5 -126.5. Following either requirement, the OP is able to use his AC within a safe, specified range.
As an aside, the (one way) resistance of 50ft of #8AWG wire is 0.031 OHMS. The round trip resistance total would be .062 OHMS. Assuming a single A/C running at 14Amps, voltage drop is (E=IxR)=14x.062= 0.868V If both A/C units are turned on, total amps would be 28, or 28x.062=1.736V drop. With 111V in at the house, minus 1.736V drop, the voltage at the RV should be about 109V. OP claims 108V or about right.
Still within "code" range of 104.4V or 103.5V for acceptable operation.
Our Travel Blog
valhalla360
No paticular place.
Posted: 09/27/22 06:58am Link  |  Quote  |  Print  |  Notify Moderator
What's the voltage if you check at the outlet?
When you apply an electrical load, one of the side effects is it pulls the voltage down. There 3 primary things that impact how much the voltage is pulled down:
- How many amps.
- How long is the electrical cable/wire run (if you coil up 100ft of cable, it still counts as 100ft)
- How thick are the wires
(there are a few other things but not too relevant to this discussion).
The air/con is generally the biggest load in an RV, so relatively high amps. (and as the voltage drops, the amps increase to compensate)
You've had to string together multiple cords, so relatively long cables.
You say it's 30amp service. Is it really 30amp service or is it a 15/20 amp household plug with an adapter. The wiring in your house counts as part of the cabling length and if it's thin, that could be increasing voltage drop.
Dropping by 3 volts is not uncommon with a heavy load like an air/con. If you are starting with a good strong supply up around 120v, that leaves you at 117v which is perfectly fine.
At 108v, that's getting borderline where I would be looking at pulling out the generator. Keep in mind, as houses in your neighborhood turn devices on and off the voltage will fluctuate, so it might be 108v while you are looking and it might drop to 105v a few minutes later.
I'm speculating a bit but if the 111v is while nothing is on in the RV (negligible voltage drop), the voltage at the outlet is likely marginal. Items you can check:
- Are all the connections in good shape with no corrosion? If you are capable, check inside the outlet and at the breaker panel for corrosion or lose wires.
- Check the voltage at other outlets around the house. If they are all down around 110v +-, it's likely nothing wrong with your RV and just that your house has low voltage. You could check with the power company but unlikely they would do anything about it.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
time2roll
Posted: 09/27/22 07:30am Link  |  Quote  |  Print  |  Notify Moderator
What is the voltage at the house main panel? 111 with minimal load seems low for a grid powered home. May need the electric company to come out and verify. s/b solid 118-122
Possibly the RV water heater is on electric and pulling the voltage down.
675w Solar pictures back up
jjj
Lancaster,Ca.U.S.A.
Posted: 09/27/22 07:42am Link  |  Quote  |  Print  |  Notify Moderator
I ran my 30 amp plug from my panel to where my trailer
is parked.I used 10/2 wire, had to run it through the
attic. I get 118/119 volts with no load but when ac runs
it drops to about 110 volts.I should have ran 8/2 even 6/2
due to the 50 ft.run and the heat in the attic during the
summer. Your voltage drops seems normal especially with extension
cords.
2002 F-350 Crew-Cab Dually
V-10-4.30 gears Mag-Hytec diff.cover
w/Amsoil-6.0 trans cooler Curt Q5 20K hitch & bedsaver
2005 Keystone Challenger 34TBH-Fifth Airbourn
BB_TX
McKinney, Texas
Posted: 09/27/22 07:55am Link  |  Quote  |  Print  |  Notify Moderator
If those are true 50 amp extension cords, voltage drop should not be the problem on 30 amp power. Starting with 111 volts and dropping to 108 when you turn on the AC makes me think you have a supply source problem. Especially since it is ok with the generator. Make sure you have 120 vac at the outlet. And make sure the outlet wiring is good and the outlet contacts are not loose, worn, or corroded.
 > Low power?
