RV.Net Open Roads Forum: Fifth-Wheels: Rotten egg smell, again???
 > Rotten egg smell, again???
freewayrandy
'Old Hangtown', Ca
Posted: 09/27/22 07:08am Link  |  Quote  |  Print  |  Notify Moderator
I read where it comes from the water heater, anode rod? So how do I get it on the cold water side when hooked up to city water?
2015 Chevy 2500HD Duramax/Allison, 2018 Grand Design Momentum 328, 2005 Polaris Sportsman 500, 2018 Polaris RZR 900
way2roll
Wilmington NC
Posted: 09/27/22 07:15am Link  |  Quote  |  Print  |  Notify Moderator
Could be a lot of sulfur or iron oxide in the water. Some bacteria live in iron rich water.
2023 FR Sunseeker 2400B MBS
mleekamp
Washington, IL
Posted: 09/27/22 07:31am Link  |  Quote  |  Print  |  Notify Moderator
Most likely from the well. Sulfer (rotten egg smell) and iron are the two most common elements in well water. We have a well at home, and have filtration to eliminate it inside the house. Filling our RV tank from home, or using water from the campground, the filters built in do help.
I suggest buying a filter set up to add to your city water hookup. Should do the trick.
BB_TX
McKinney, Texas
Posted: 09/27/22 07:47am Link  |  Quote  |  Print  |  Notify Moderator
Some who have clothes washer hookups but no washer have reported a bad water odor over time due to stagnant water in those water lines. Solved it by adding cutoff valves in the pipes near where they branch off from the main lines.
freewayrandy
'Old Hangtown', Ca
Posted: 09/27/22 08:56am Link  |  Quote  |  Print  |  Notify Moderator
We were at an RV park and no one else had the issue. I've changed my filters to no avail.
corvettekent
Marysville, WA
Posted: 09/27/22 09:00am Link  |  Quote  |  Print  |  Notify Moderator
If you have flooded lead acid batteries, you should check the water level.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Turnover Ball, Companion Hitch.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
midnightsadie
ohio
Posted: 09/27/22 09:12am Link  |  Quote  |  Print  |  Notify Moderator
yep sounds like your batteries are boiling smells like rotten eggs.
lhenry8113
Cypress or Lake Arrowhead, Ca.
Posted: 09/27/22 11:06am Link  |  Quote  |  Print  |  Notify Moderator
House battery burning up-check water level.
2017 Chev/CLass C Forest River Forester 2251 SLE
A Positive Attitude May Not Solve All Your Problems But It Will Annoy Enough People To Make It Worth The Effort.
H Albright
freewayrandy
'Old Hangtown', Ca
Posted: 09/27/22 11:38am Link  |  Quote  |  Print  |  Notify Moderator
Maybe I'm an idiot but can't quite see how battery water level affects my water supply.
BB_TX
McKinney, Texas
Posted: 09/27/22 11:43am Link  |  Quote  |  Print  |  Notify Moderator
It doesn’t. If you only get the smell when you run water then it has something to do with your water system. Or park water. See if it has odor coming out of the park faucet.
