RV.Net Open Roads Forum: Fifth-Wheels: Rotten egg smell, again???
 > Rotten egg smell, again???
Skibane
San Antonio, TX
Posted: 09/27/22 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
lhenry8113 wrote:
House battery burning up-check water level.
If they're low on water, also check the voltage they're being maintained ("floated") at - If it's more than 13.8, you've got a problem with the house battery charger.
Retired JSO
North Georgia Mountains
Posted: 09/27/22 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
Happens when minerals react if WH is not used for a few weeks either with or without anode rod. If on full hookups just run water through water heater for 20-30 minutes and the smell will go away.
midnightsadie
ohio
Posted: 09/28/22 04:36am Link  |  Quote  |  Print  |  Notify Moderator
WELL did you find the problem? lot good answers.
schlep1967
Harrisburg, PA
Posted: 09/28/22 05:45am Link  |  Quote  |  Print  |  Notify Moderator
Turn off water heater, turn off water, remove plug or anode from water heater and drain the tank (unless you have a valve to do so). Replace plug/anode/close valve, and refill the tank with water.
Trying to flush it out by simply running good water into 10-12 gallons of smelly water will take forever.
2021 Chevy Silverado LTZ 3500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide 4500
freewayrandy
'Old Hangtown', Ca
Posted: 09/28/22 06:54am Link  |  Quote  |  Print  |  Notify Moderator
BB_TX wrote:
freewayrandy wrote:
Maybe I'm an idiot but can't quite see how battery water level affects my water supply.
It doesn’t. If you only get the smell when you run water then it has something to do with your water system. Or park water. See if it has odor coming out of the park faucet.
I'm the only one out of 5 in our group that had the smell so not the park water. So must be my system. Yesterday, drained water heater, flushed it, lots of white crud came out, put in new anode rod. Sanitized fresh tanks, 1/4 cup bleach per 15 gals. Ran all taps to get solution thru entire system. So far no egg smell. Run more today then drain and flush again.
2015 Chevy 2500HD Duramax/Allison, 2018 Grand Design Momentum 328, 2005 Polaris Sportsman 500, 2018 Polaris RZR 900
2112
Posted: 09/28/22 07:59am Link  |  Quote  |  Print  |  Notify Moderator
I believe the zinc anode rod is better for eliminating the rotten egg smell
2013 KZ Durango 2857
Samsonsworld
West Texas
Posted: 09/28/22 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
I have to flush and bleach the heck out of my tanks sometimes.
freewayrandy
'Old Hangtown', Ca
Posted: 09/28/22 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
After flushing everything, smell is gone. Thanks for all the help.
