RRinNFla
Northeast Florida
Just finished a 3 week road trip with my 2022 F250 and new companion hitch. Much smoother ride than my old Pullrite slider.
But, on a couple of occasions I had trouble opening the jaws. In one instance I was backing uphill into the campsite and when I put the TV into park it moved slightly downhill. I had DW get in the cab, put TV into Reverses and was able to release jaws once forward pressure was removed.
In the second instance, on level ground, after I got my rig in the spot I wanted and put landing gear down, I was maybe 3 to 5 degrees away from having TV and rig in alignment. I could not open the jaws, so I had to raise the landing gear, pull forward and then back up till TV and rig were perfectly aligned. Then I could open the jaws.
I was used to the Pullrite being more forgiving on angles. Any suggestions from experienced Companion owners,
Richard
2015 Prime Time Crusader 295RLT
2008 Ford F250 V10 (Gas), EC, SB, 4X4
MFL
Midwest
Due to the cam action of the jaws, the pin will keep them in the wrap around position, with pull/tension against them. In my experience, locking the handle open with pin, will still allow jaws to release, even though they are wrapped around yet. You just need to have landing gear down, pull ahead. Mine will open, and yours should too.
Your Companion should allow hitching/unhitching at normal angles, and be MORE forgiving than most.
Jerry
corvettekent
Marysville, WA
I have had mine bind when trying to unhitch, when this happens, I leave the landing gear down and put the transmission in neutral to release the pressure on the hitch.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
Cummins12V98
on the road
Lock handle in open position and pull away. Be sure to remove the locking pin as soon as possible!!!
Your President of the "B&W HeavyWeight FanBoy Club".
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ford truck guy
Pennsylvania
^^ what the Prez said ! ! !
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Cummins12V98
on the road
ford truck guy wrote: ^^ what the Prez said ! ! ! ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif)
Sucking up again I see.
blofgren
Surrey, B.C.
X2 on pinning the handle open. It will release even though the jaws are still wrapped around the pin; I just had to do this on this past weekend when camping.
I also agree with removing the pin right away afterwards; when hooking up to leave my hitch wouldn't latch until I realized that it was still pinned open....
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
GIB2
Welland
I've had B&W for close to ten years and didn't know that invaluable info. Thank you for sharing that . It's pretty straight forward when you know . I don't know you other than on this sight. People could learn a lot from you if they chose to listen rather than saving a couple of dollars.
schlep1967
Harrisburg, PA
It's amazing what you can learn from your owners manual.
Companion Manual
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
Cummins12V98
on the road
" I don't know you other than on this sight. People could learn a lot from you if they chose to listen rather than saving a couple of dollars."
Thanks!
I didn't just happen to become a "B&W FanBoy" a friend kept praising his B&W setup and I finally listened and the rest is history some 20 years ago!.
