TurnThePage
North ID
Because my old travel trailer may need to be permanently occupied for the next 6 months or so, I'm considering adding an electric heating element to the gas only water heater. The tank is aluminum, and it looks like the available kits use brass fittings. I'm concerned about galvanic corrosion. Anybody have experience with these things?
2015 Ram 1500
2004 Pioneer 18T6
agesilaus
North Florida
Not with the kits, but yes Aluminum and Brass will set up a galvanic cell. Putting a insulating gasket in between the brass fitting and the tank may prevent the corrosion. A piece of teflon or rubber would work.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
Superbumper
Bumpyroad
Virginia
On one of my gas only water heaters I added a hot ROD I think it was called.
worked but a bit slow.
bumpy
opnspaces
San Diego Ca
I may be wrong but I don't think galvanic corrosion happens very fast.
I would probably buy a electric element and screw it into the tank. Then after 3 months turn off the water heater and let the tank cool. Then pull the element and see if you notice any corrosion on the threads. It none then screw the element back in and check again in another 3 months.
After your 6 months remove the element and put the plastic drain plug back in.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
TurnThePage
North ID
Yeah, I've already ordered a kit and will likely take that approach.
Thanks All!
agesilaus
North Florida
Quote: Then pull the element and see if you notice any corrosion on the threads. It none then screw the element back in and check again in another 3 months.
Unfortunately the corrosion will occur on the aluminum side not the brass side. Aluminum will form the anode. I'd expect corrosion to occur at the contact zone between the brass and aluminum.
If the tank has a sacrificial anode, which it probably does not in a propane only heater, that may corrode instead of the aluminum.
pianotuna
Regina, SK, Canada
There is one kit that includes a magnesium rod to protect the aluminium.
Regards, Don
midnightsadie
ohio
wrap the threads with teflon tape good. slow things down
$20 says you won't use anywhere near $120 (cost of a hot rod kit) in propane heating your water for 6 months.
Something to consider.
agesilaus
North Florida
pianotuna wrote: There is one kit that includes a magnesium rod to protect the aluminium.
That will work
